Package tray corner trim
Old August 14th, 2018, 07:16 PM
AJFink's Avatar
Just got the corner trim pieces from Inline Tube. Am I going to have to trim to fit? Looks to wide
Repop package tray corner.
AJFink is offline
Old August 14th, 2018, 07:57 PM
70Post's Avatar
Those are for a Cutlass "S" bodystyle -- yours, being a Supreme, uses a different style and likely not repro'd (but check anyway).
70Post is offline
Old August 14th, 2018, 08:04 PM
70Post's Avatar
Here's what the correct package tray corners will look like (see pic).
Not for sale at this time....check with Scott (Oldspackrat)....watch for severely "dried out" ones and warped pieces (from serious sun/heat exposure combined with an overtightened mounting screw).
70Post is offline
Old August 14th, 2018, 09:06 PM
vette442's Avatar
I'm sure I have an extra one or two in my Supreme parts stash. If you're interested, I'll take a look.
Terry
vette442 is offline
Old August 15th, 2018, 07:21 AM
AJFink's Avatar
"I'm sure I have an extra one or two in my Supreme parts stash. If you're interested, I'll take a look.
Terry"
Yes please see if you have both. You can contact me via email ajfink57@msn.com
AJFink is offline
Old August 15th, 2018, 04:31 PM
Patton, my corner trims on my Cutlass S are made from metal, not plastic. Is the Supreme different that way too?
Allan R is offline
Old August 15th, 2018, 07:41 PM
70Post's Avatar
Alan - I've pulled a couple dozen sets of these from all kinds of GM 69-72 Abodies (mainly Cutlass S bodies and Skylarks) and have never seen them in metal. You sure about that?? They have a metal "insert" around the screw hole but again, I've never seen any with a metal "body".
I did attempt to make a pair from metal one time for a car but stopped the "project" as it was a real PITA.
70Post is offline
Old August 16th, 2018, 07:25 AM
The Monte Carlo ones are repopped and the Monte tub has the same roofline as the Cutlass Supreme.
https://www.opgi.com/monte-carlo/CHV4585/
They look similar enough I'd try them.
Koda is offline
Old August 16th, 2018, 09:08 AM
70Post's Avatar
The Monte Carlo pieces appear to be shorter than the Supreme pieces...I'm referring to the horizontal length.
Still, they may work but I could see where you would need to drill a new hole in the back window "crossbar" as the difference in length puts the screw hole in a different position.
70Post is offline
Old August 16th, 2018, 03:27 PM
oldspackrat's Avatar
I have pulled many of these also & have never seen any metal ones.
oldspackrat is offline
Old August 16th, 2018, 03:29 PM
I'm going to have to go out and pull one of mine to see. Maybe it's the reinforcing around the screw hole that fooled me.
Allan R is offline
Old August 30th, 2018, 08:14 PM
vette442's Avatar
Terry"
Still need these? I have a good LH (drivers side) one available.
Terry
vette442 is offline
MBrown
July 10th, 2015 11:10 PM
biggus
March 1st, 2015 05:37 PM
steverw
December 31st, 2014 02:22 PM
Chumley
February 25th, 2011 02:15 AM
richeyb
May 30th, 2010 07:34 PM
Quick Reply: Package tray corner trim
