Package tray corner trim
Old Aug 14, 2018 | 07:16 PM
AJFink's Avatar
Just got the corner trim pieces from Inline Tube. Am I going to have to trim to fit? Looks to wide
Repop package tray corner.
Old Aug 14, 2018 | 07:57 PM
70Post's Avatar
Those are for a Cutlass "S" bodystyle -- yours, being a Supreme, uses a different style and likely not repro'd (but check anyway).
Old Aug 14, 2018 | 08:04 PM
70Post's Avatar
Here's what the correct package tray corners will look like (see pic).
Not for sale at this time....check with Scott (Oldspackrat)....watch for severely "dried out" ones and warped pieces (from serious sun/heat exposure combined with an overtightened mounting screw).
Old Aug 14, 2018 | 09:06 PM
vette442's Avatar
I'm sure I have an extra one or two in my Supreme parts stash. If you're interested, I'll take a look.
Terry
Old Aug 15, 2018 | 07:21 AM
AJFink's Avatar
"I'm sure I have an extra one or two in my Supreme parts stash. If you're interested, I'll take a look.
Terry"
Yes please see if you have both. You can contact me via email ajfink57@msn.com
Old Aug 15, 2018 | 04:31 PM
Patton, my corner trims on my Cutlass S are made from metal, not plastic. Is the Supreme different that way too?
Old Aug 15, 2018 | 07:41 PM
70Post's Avatar
Alan - I've pulled a couple dozen sets of these from all kinds of GM 69-72 Abodies (mainly Cutlass S bodies and Skylarks) and have never seen them in metal. You sure about that?? They have a metal "insert" around the screw hole but again, I've never seen any with a metal "body".
I did attempt to make a pair from metal one time for a car but stopped the "project" as it was a real PITA.
Old Aug 16, 2018 | 07:25 AM
The Monte Carlo ones are repopped and the Monte tub has the same roofline as the Cutlass Supreme.
https://www.opgi.com/monte-carlo/CHV4585/
They look similar enough I'd try them.
Old Aug 16, 2018 | 09:08 AM
70Post's Avatar
The Monte Carlo pieces appear to be shorter than the Supreme pieces...I'm referring to the horizontal length.
Still, they may work but I could see where you would need to drill a new hole in the back window "crossbar" as the difference in length puts the screw hole in a different position.
Old Aug 16, 2018 | 03:27 PM
oldspackrat's Avatar
I have pulled many of these also & have never seen any metal ones.
Old Aug 16, 2018 | 03:29 PM
I'm going to have to go out and pull one of mine to see. Maybe it's the reinforcing around the screw hole that fooled me.
Old Aug 30, 2018 | 08:14 PM
vette442's Avatar
Terry"
Still need these? I have a good LH (drivers side) one available.
Terry
MBrown
Jul 10, 2015 11:10 PM
biggus
Mar 1, 2015 05:37 PM
steverw
Dec 31, 2014 02:22 PM
Chumley
Feb 25, 2011 02:15 AM
richeyb
May 30, 2010 07:34 PM
