Package tray corner trim
Here's what the correct package tray corners will look like (see pic).
Not for sale at this time....check with Scott (Oldspackrat)....watch for severely "dried out" ones and warped pieces (from serious sun/heat exposure combined with an overtightened mounting screw).
"I'm sure I have an extra one or two in my Supreme parts stash. If you're interested, I'll take a look.
Terry"
Yes please see if you have both. You can contact me via email ajfink57@msn.com
Terry"
Alan - I've pulled a couple dozen sets of these from all kinds of GM 69-72 Abodies (mainly Cutlass S bodies and Skylarks) and have never seen them in metal. You sure about that?? They have a metal "insert" around the screw hole but again, I've never seen any with a metal "body".
I did attempt to make a pair from metal one time for a car but stopped the "project" as it was a real PITA.
The Monte Carlo ones are repopped and the Monte tub has the same roofline as the Cutlass Supreme.
https://www.opgi.com/monte-carlo/CHV4585/
They look similar enough I'd try them.
The Monte Carlo pieces appear to be shorter than the Supreme pieces...I'm referring to the horizontal length.
Still, they may work but I could see where you would need to drill a new hole in the back window "crossbar" as the difference in length puts the screw hole in a different position.
Terry"
Terry"
Terry
