dash pads
Old Dec 15, 2022 | 02:56 PM
Chuxter's Avatar
1970 Cutlass Supreme
dash pads
Can Dash pads be repaired or re painted/Dyed?
Old Dec 15, 2022 | 03:59 PM
Tri-Carb's Avatar
You could send it to Just Dashes on the west coast. I would say that the total cost, including shipping, may approach $1500.
There are some home repair videos on U-tube. Here is an example:
https://m.youtube.com/watch?v=2INF3RJEn08
Old Dec 16, 2022 | 08:36 AM
oddball's Avatar
They can be painted, but good adhesion is difficult.
Old Dec 16, 2022 | 08:46 AM
4speed455's Avatar
SEM paint can be used to to re-color vinyl and plastic interior pieces including dashes. I’ve used their Landau Black rattle cans with good success in the past.
Old Dec 16, 2022 | 09:07 AM
oldsobsolete's Avatar
Every used car lot has someone that repair's tears in vinyl seats or cracks in dashes. They use dye to color match the color and some of these guys are real artists
There may be someone local that can help you. God Luck
Old Dec 16, 2022 | 10:35 AM
Lots of options for repairing a cracked dash.
https://classicoldsmobile.com/forums...ow-fix-159415/
https://classicoldsmobile.com/forums...repair-143071/
https://classicoldsmobile.com/forums...repair-153270/
Eventually, I at least want to get a Covercraft dash cover for my 71 98. It's better than sporting a cracked dash.
Old Dec 16, 2022 | 06:03 PM
70Post's Avatar
Adhesion is not a problem when painting/dying a dash pad. You need to clean/scrub the heck out of them first w/plenty of hot water and whatever cleaner you use. Then use a good adhesion promoter on the surface prior to painting. Have done A LOT of dash pads and adhesion has never been a problem.
Old Dec 17, 2022 | 06:25 AM
Tri-Carb's Avatar
This is also my experience. Plus a lacquer based paint seems to adhere the best to a plastic surface.
Old Dec 19, 2022 | 05:48 AM
oddball's Avatar
¯\_(ツ)_/¯
I used PPG DBC paint to get the specific blue I like, did plenty of prep including SEM's cleaner and adhesion promoter. Two different dash pads, pretty certain neither were contaminated with armor all. Same problem - high contact areas, like the corners where it comes up against the door cards, will wear through within a year or so. Thankfully it's covered when the doors are closed, but I get a little flash of that ugly gold every time I get in the car.
Using vinyl dye will make it easier, and dying darker or back to the same color would be easier. It's hard to start lighter than blue so I'm always having to cover - ends up being 4 coats or something.
Old Apr 19, 2023 | 05:07 AM
chopolds's Avatar
I believe there are 3 options. Expensive repairs, like Just Dash's, Hack repairs, with bondo, and bedliner, or some other textured paint, OR...try a local upholstery shop. Mine will stitch or glue the crack together, then sew a vinyl cover for it, that looks as good or better than original.
Old Apr 19, 2023 | 05:43 AM
I wouldn't call using a filler a "hack" repair.
Even if you have a dash redone by Just Dashes, what are the chances that it will crack again given enough time? Plus, don't use bondo to repair the crack. Use a plastic welder like Polyvance. It's specifically engineered to repair dashes.
brotherGood
Dec 1, 2022 07:00 AM
gratsoy
Sep 24, 2021 08:55 PM
rickbmac
Jul 16, 2016 04:27 AM
rktolds
Dec 8, 2015 02:08 PM
bonezarally
Sep 19, 2010 09:26 AM
