Anybody have experience with these clock tachs?
Old Apr 13, 2014 | 07:03 PM
CyberCholo's Avatar
I wan't a tach for my car so I can actually be sure when I'm shifting haha, and the clock is broken anyways, and fixing the clock seems silly when I can put a clean little tach there, just wondering if anyone has used the same kit, and how hard it is to install? If I have an aftermarket dizzy I just have to run a wire to the tach hookup on the dizzy right? But if I have a stock one I imagine its harder? I haven't taken a close look at my dizzy yet but I just noticed today it has a brand new black cap on it, so I dunno if it just had the cap and rotor replaced or its an aftermarket, is there an easy way to tell?
http://www.shiftworks.com/tachs-nova.htm#1968
Old Apr 22, 2014 | 11:23 AM
Should be a straight forward install by the looks of it. If your after market HEI distributor has a 'tach' terminal, yes you can hook it up just as you described. If you have a stock distributor (points?) the install isn't really that hard. The tach wire goes to the negative side of the coil.
Old Apr 24, 2014 | 01:53 PM
CyberCholo's Avatar
Thanks dude!
Old Apr 24, 2014 | 04:59 PM
Or you could do this with a regular old aftermarket tach. I guess it depends upon what size the hole in your dash is.
https://classicoldsmobile.com/forums...s-supreme.html
In my 72 I used a sunpro suntach in a gutted column shift speedo housing fits in there nicely and I think it looks OK
Old Apr 24, 2014 | 05:58 PM
Ken, it's in a 73 Omega.
Have a look at this page. What he wants to consider is putting that shiftworks.com tach where the clock is - to the right of the speedo.
jfb
Aug 8, 2015 12:05 PM
815Cutlass1972
Jan 7, 2013 07:58 PM
sx455raidercelticfan
Jul 9, 2010 02:51 PM
my69olz
May 18, 2009 03:40 AM
mikebass2112
Jan 8, 2008 08:17 PM
