What size aftermarket tach fits in the dash of a 1968 Olds Cutlass Supreme?
Old Apr 7, 2013 | 07:07 PM
six8olds's Avatar
What size aftermarket tach fits in the dash of a 1968 Olds Cutlass Supreme? From researching I think it would be the 3 3/8", but I am not sure. Any help would be appreciated. Thank you!
Old Apr 8, 2013 | 04:01 PM
six8olds's Avatar
Surely, someone knows or has done this.
Old Apr 8, 2013 | 04:31 PM
allyolds68's Avatar
This was mine. It was a Mercruiser tach but I sold it so I can't tell you for sure what size it was. I think it was 3 1/2". A stock gauge is about 4 1/4" so anything smaller than that will fit
Old Apr 8, 2013 | 05:30 PM
six8olds's Avatar
I like that. It looks really nice. Did it fit in without much modification?
Old Apr 8, 2013 | 05:49 PM
allyolds68's Avatar
I used a 3 1/2" hole saw to cut a hole in a clock delete plate and used that to mount it but with a little tweaking you could gut any factory gauge to act as a mounting pod
I found another pic I have of it. It came out nice. If I didn't find a nice factory tach/gauge set I never would have gotten rid of it
Old Apr 9, 2013 | 12:45 PM
1970-W30's Avatar
Or how about this one, made to match the other gauges and fit right in without any modifications, replaces the clock or blank plate. OPGI at around $145
Old Apr 9, 2013 | 03:07 PM
six8olds's Avatar
I have read on these forums that those repro pieces are kinda junky and made of plastic. I've even seen one that wasn't completely sealed. That's why I want a nicer unit, such as the American Muscle unit from Autometer.
Old May 16, 2013 | 08:46 AM
SWinner's Avatar
I bought one of those pieces of junk. It doesn't work with an MSD ignition. I bought mine when I first started my restoration. By the time I was able to start the engine, it was out of warranty. I called the dealer and they put me in touch with the guy that makes it. When I told him my setup, he criticized me for using an MSD box. Says it works with points or an HEI. I have an HEI triggered by a 6AL. He gives me move grief about the MSD. He finally told me that the movement inside was from some 80’s GM car. No help other than that.
I called the MSD tech line and they said that the 80’s something tach movement should work when plugged directly into the 6AL’s tach output. It didn’t. They suggested that I try a MSD 8920 Tach Adapter. Well another $60 and that made it work, well sort of. By the time I finished the restoration and put the pedal to the floor, I discovered when my MSD rev limiter hit 6400 rpm, the tach was reading 5000. Not another penny on this piece of ….
Before the restoration I had a cheap Auto Gage tach that worked perfectly with my setup. I just wanted something that looked original.
Buyer beware…
Old May 16, 2013 | 01:09 PM
RetroRanger's Avatar
72 Olds CS
In my 72 I used a sunpro suntach in a gutted column shift speedo housing fits in there nicely and I think it looks OK
IDK if the 68 guage holes are the same diameter as the 72
Old May 16, 2013 | 02:03 PM
garys 68's Avatar
Is the 68 the same size as 72?
If so, 3 3/8" fit perfectly.
Old May 18, 2013 | 01:24 PM
Majic Jack's Avatar
Gary those look real nice, please provide brand and availability. Thx.
Old May 18, 2013 | 04:25 PM
garys 68's Avatar
Dolphin gauges, search google or ebay. No mods, bolted right in.
Old Nov 14, 2014 | 04:43 AM
westside807's Avatar
more information
Hello Mr Gary! I know this thread is old but I'm at the gauge stage and as far as i know yours is the only post that says "no modification bolt right up" that's what i need I'm definitely a newbie. My real question is how does your Dolphin gauges look at night? Do you have any pictures of them illuminated? Thanks
RAMBOW
May 3, 2022 04:25 PM
68s350
May 10, 2014 12:41 PM
1966Oldsmobile
Jan 14, 2013 10:29 AM
slipbakka
Jul 6, 2007 01:28 AM
