olds tachs and aftermarket ignition compatability.
Old Aug 8, 2015 | 12:05 PM
jfb's Avatar
jfb
Thumbs up olds tachs and aftermarket ignition compatability.
1 I could be wrong here and maybe I posted this before. I have a crane ignition and a olds factory tach combo. I found that you can peel back the sheething on the olds tach wire and find a wire there to run a connector with to the aftermarket ignition, I used posi connectors and it is working excellent. I would though suggest that you paint the tach indicator orange for easier visibility. crane did not have a direct way to hook this up so I easily improvised and destroyed nothing. I ran the olds tack parallel with a engine rpm indicator and the two were almost dead on with each other. this is another way to use better technology and our personal rides toghether again.
CyberCholo
Apr 24, 2014 05:58 PM
sx455raidercelticfan
Jul 9, 2010 02:51 PM
66starfire
Aug 2, 2007 09:55 AM
gous44ls
Mar 25, 2007 01:50 AM
66starfire
Dec 20, 2006 01:41 AM
