Any Suggestions?
Old Apr 16, 2009 | 04:34 PM
Snowdog's Avatar
Any Suggestions?
My 65 Olds convertible top goes down just fine. But, when I try to put it back up, it needs a little assistance for a quarter of the way and then, it is fine. Is it just low on fluid or something else?
Thanks,
Kevin
Old Apr 17, 2009 | 03:16 AM
Yellowstatue's Avatar
Smile Heave ho
It sounds like you are low on oil, there should be a small plug in the top of the pump body, use dexron, and use a syringe to put the stuff in, have rags handy because we are sloppy and voila...cycle the top up and down a couple of times to get rid of the air bubbles...
Old Apr 17, 2009 | 03:22 PM
Snowdog's Avatar
Thanks Yellowstatue.
Type A Fluid?
Old Apr 17, 2009 | 07:25 PM
Snowdog's Avatar
Is it easier to get to it thru the trunk or do
I take all the screws off in the inner deck?
Never have done this before
Old Apr 18, 2009 | 02:00 AM
Smile Stuffed
I don't know what the inside of your trunk is like...but on a Cutlass we go in through the trunk and under the dust cover for the top...it's a little awkward but don't wear your Sunday clothes... Yes on the type A trans fluid...
Last edited by Yellowstatue; Apr 18, 2009 at 02:02 AM. Reason: Forgot something, duh
Old Apr 18, 2009 | 05:37 AM
wolfman98's Avatar
Captain of my ship
I have a similar problem with my 69-98 but not sure how to get to the pump. Would I have to remove the cardboard to see the pump? Do you do this on your cutlass or is the dust shield on the trunk side?
Old Apr 18, 2009 | 06:02 AM
Snowdog's Avatar
My Cutlass has a metal shield covering the motor in the trunk
I guess I will contort my body to get to it
No it was cardboard
Old Apr 18, 2009 | 03:25 PM
dingusboy's Avatar
Does dexron make an A type ATF? If not, what is the equivalent?
Old Apr 18, 2009 | 05:05 PM
Snowdog's Avatar
Well its done. Not a messy job. It was a cardboard cover,
used a ear syringe to fill it. It took about 4oz, Dextron VI
no type A avalible. After working the air bubbles out I was
able to put another ounce in. Works fine now.
Thanks Guys for your advice.
Kevin
Old Apr 18, 2009 | 06:55 PM
csstrux's Avatar
Old Apr 18, 2009 | 09:19 PM
Smile Pumped
Go through the trunk, remove dust cover, replenish fluid, replace dust cover, eject!!! Type A fluid evolved into Dexron and so on and so on, I, II III, IV
EightballZ
Paint
Dec 7, 2012 05:54 PM
amesolds
Dec 1, 2012 07:00 PM
agtw31
May 28, 2010 11:38 AM
CUT-N-UP
Oct 27, 2009 06:52 PM
blood sweat and oil
Mar 19, 2009 08:43 AM
