69 Olds 442
Old Nov 30, 2019 | 06:20 AM
tmd442's Avatar
69 Olds 442
I've been a member here for 2 years and recently picked up a 1969 Olds 442, 4speed.
I've been looking for awhile and finally found the one
Anyway, Started doing basic maintenance, oil change, air filter, PCV and some minor interior work
Now the fun part, I tried replacing the fuel filter and the hard fuel line coming off the fuel pump to the carb hit the T-Stat housing.
Is there some trick to removing it without having to remove the T-Stat housing? I figured it would only take me 10 minutes at the most to do this but No.
Tom
Old Nov 30, 2019 | 06:45 AM
rocketscientis's Avatar
Fuel delivery line
Hav to assume end is rusted tight
best bet is to remove whatever you hav to to get pump / line /carb off..thats if line is Worth saving
I have used acid from eyedrop bottle & back n forth with a quality line wrench with great success but dont recomend it...need fan for ventilation ..rags water & bakin soda..glasses gloves respeatr
If u can get an end off...remove line & what its attachec to , to a goog place to operate on it
BE CAREFUL NOT 2 DAMADGE THREADS IN CARB
take your time....not goin to b quick...it is doable
Old Nov 30, 2019 | 06:49 AM
tmd442's Avatar
Thanks for the info,
I can loosen the steel line flare nut from the carb but there isn't enough room to pull it out of the fuel inlet fitting.
The line hits the T-Stat housing.
Old Nov 30, 2019 | 06:54 AM
Line
if you can loosen the other end and disconnect it from the fitting that goes in the pump that should do you
Old Nov 30, 2019 | 07:04 AM
tmd442's Avatar
I'll give that a try, Thanks I appreciate your help.
Gave it a try and didn't work.
I think I'll cut the line prior to the flare nut, remove it then remove the long inlet fitting and replace it with the short inlet fitting as well as a new fuel line.
I really don't want to remove the thermostat housing.
Old Nov 30, 2019 | 01:21 PM
Why not? It's not that big a deal.
Old Nov 30, 2019 | 02:03 PM
6 of 1 1/2 dozen th other
decide for yourself the Lesser of evils think what you meant to say was I really don't want to pull the carb off n break the seal th gasket has to intake
seeing as how your fuel line unthreaded I'd say those two bolts in the thermostat should come out easily as well and if its an aluminum one should be inspected for corrosion anyway from the inside out
Old Nov 30, 2019 | 02:51 PM
tmd442's Avatar
Remove the thermostat it is.
guess I just needed a little push.
Old Nov 30, 2019 | 03:16 PM
Nice car, BTW!
Old Nov 30, 2019 | 03:25 PM
tmd442's Avatar
Nice car, BTW!
Old Nov 30, 2019 | 04:46 PM
Check housing to make certain its not oxidizing from inside out..while off if new thermostat installed ..boil it to c if it opens
Old Nov 30, 2019 | 06:10 PM
tmd442's Avatar
good info on the thermostat
Old Nov 30, 2019 | 09:11 PM
BackInTheGame's Avatar
VERY Sharp ride
Old Dec 1, 2019 | 04:26 AM
tmd442's Avatar
VERY Sharp ride
I appreciate it.
BrawnyMan
Aug 13, 2019 11:01 AM
Kirk455
Aug 8, 2019 09:49 AM
DanOldsMan
Feb 10, 2014 07:18 AM
defiant1
Apr 2, 2011 09:58 AM
wikkonado
Jul 8, 2010 08:22 PM
