1969 door locks
1969 door locks
The door locks on my 69 supreme are giving me some trouble. I have the door panels removed so I can view the mechanism and everything appears to be fine but when I shut the doors with the locks engaged they unlock. Also when sitting in the car with the doors closed I can lock the doors no problem. I realize something is causing the lock to disengage when the door is shut but I can't see any problems. Any suggestions?
When the door is open and you push the lock button down, then push the door handle button in and then shut the door. '68 works that way also. My '69 GMC must lock with the key. If you remove the lock cylinders and clean the outside you will find a code on there and get keys cut at the dealers for said cylinders.
There should be a horseshoe clip that holds lock in from back. Slide the clip usually left or right but sometimes up or down. Lock will pull out from front. Take to a local locksmith. Dealers make enough already.
Kevin
Kevin
cherry62olds
Apr 3, 2008 10:59 AM
