POWER DOOR LOCKS 81 olds regency98
Old Oct 16, 2005 | 10:12 AM
DonFrost's Avatar
Unhappy
I have a problem. My door locks lock with the switch but will not unlock. When I unplug the circut breaker (from the fuse block)and hit the lock switch I can hear a clicking from a relay in the passenger side kick panel. I inspected it and it looks like a relay. I can not find it for sale anywhere so I don't know if this is right.
It is a 1981 Olds Regency 98. I traced the wires and they are all good. I also unplugged the switch and tested the wires and jumpered them to make it unlock, Is it a possibility that both of my door lock switches are bad? ANY HELP PLEASE
Old Oct 16, 2005 | 08:58 PM
texasred's Avatar
Tom Servo's Stunt Double
Post
Had a similar problem in my '90 J**p Cherokee. Affected only left front and right rear doors. Troubleshot electrics, cleaned and lubed lock mechanisms, no fix. Learned to live with it for the last 2 years. Replaced negative battery cable a couple of months ago for massive corrosion...they now work! Try cleaning the body ground strap connections and replacing negative battery cable.
C.J.
Old Oct 22, 2005 | 03:30 PM
DonFrost's Avatar
Post
Thank you. I will try that.
Olds luvr
Mar 19, 2015 09:34 AM
Blaster
Jul 28, 2011 03:15 PM
1983oldsmobiledelta
Oct 2, 2010 05:54 PM
Mike77
Dec 6, 2009 05:24 PM
jeffreyalman
Jun 15, 2009 08:04 AM
