Whats wrong with this picture?
Old July 24th, 2011, 09:55 PM
Kjr442
kjr442's Avatar
Unhappy Whats wrong with this picture?
I almost cried when I walked in the shop and saw this.
kjr442 is offline
Old July 24th, 2011, 10:19 PM
2blu442's Avatar
I hope his quality of work doesn't match his care for your car and the parts you provided
2blu442 is online now
Old July 24th, 2011, 10:27 PM
Kjr442
kjr442's Avatar
John he cut my NOS quarter panel below the factory seam. I meant to put this in general discussions, but I don't know how to move it now.
kjr442 is offline
Old July 25th, 2011, 04:01 AM
firefrost gold's Avatar
The one in the trunk didnt look to bad why did he swap it out ? Or am I just blind .
firefrost gold is offline
Old July 25th, 2011, 04:27 AM
69442C's Avatar
The reason he cut the panel where he did is because the full panel fits under the drip rail. Removing the drip rail to fit the panel under it is a lot more work and there is a risk of ruining the drip rail too. You'll be fine with the way it was done as long as everything is welded correctly. This shows why communication is important when you turn a car over to someone esle to do work for you. You need to be crystal clear as to what you want done, have it in writing and have an agreed method for handling other problems or issues as they come up. In the end, you may have agreed to this method of installation if it was explained to you what was involved or you would have been told what the extra cost would be to have it done as you wished.
With this said, I am concerned how the other quarter is placed in the car and the appearance of the shop.
69442C is offline
Old July 25th, 2011, 05:38 AM
Kjr442
kjr442's Avatar
Your right the one in the trunk is perfect, thats for the other side.
kjr442 is offline
Old July 25th, 2011, 05:56 AM
Kjr442
kjr442's Avatar
I was told this car would be on a rotisserie, and I would have the frame back so I could do the drive train.
All seams were to go back like the factory, this was all in writing. I have spent allot of money getting full quarters.
This is something I have waited on for 20 years now, and I am real down about it now. this was supposed to be a good experience.
kjr442 is offline
Old July 25th, 2011, 08:54 AM
Rickman48's Avatar
Since a rotisserie clamps on the cowl and rear panel of the body. I'd want the qtr. installed the way they're doing it!
If anything were to flex, [floor roof, other qtr.] it'd be a real mess to straighten out!
What's going to hold anything straight on a rotisserie with a qtr. cut off? Or both, for that matter! If the floor is weak, It'd fold in 1/2!
Personally, I'd be happy where he cut the sail panels, as those drip rails are pretty hard to find, and a real PIA!
Rickman48 is offline
Old July 25th, 2011, 10:02 AM
B964's Avatar
It is not what you wanted but it will be fine that way. What he should have done was bring you down and explain what he was going to do. That way it would have been your choice to poss damage the drip rail or do it his way. A factory NOS quarter? That must have set you back a bit.
A messy shop does not always mean a poor repair person. I have seen great work from some real pigs and crappy work from neak freaks.
B964 is offline
Old July 25th, 2011, 12:21 PM
Kjr442
kjr442's Avatar
Your right about the frame, I just wish he had covered it as much as possible. The quarters are fine, I guess. This is just not what I was told I would have,and I spent so much time and money getting both quarters.
To think about this N O S quarter making it through all of these years, and now, it's not much better then a after market. I am just so disappointed now.
kjr442 is offline
Old July 25th, 2011, 12:36 PM
69442C's Avatar
Honestly, you are just fine with the way this was installed and if it were me, I wouldn't lose one bit of sleep over it. I would also be telling the guy to do the other side the same way. And you a light years ahead of any aftermarket panel. Nothing beats factory original sheetmetal. If the rest of the panel was fully installed and there was just that small section cut at the top, you are good to go. The shop should have explained all of this to you and showed you why they would do it the way they did just to eliminate any issues since they agreed to do otherwise. But if this is the biggest issue you run into, you are home free. Cheer up and focus your efforts into other areas. You have a lot more work to do. Good luck with it and keep the photos coming.
69442C is offline
Old July 25th, 2011, 12:53 PM
Past Administrator
Oldsguy's Avatar
...I meant to put this in general discussions, but I don't know how to move it now.
Done!
Oldsguy is offline
Old July 25th, 2011, 01:02 PM
Kjr442
kjr442's Avatar
Smile
Originally Posted by Oldsguy
Done!
Thank you Dan. Have a good one!
kjr442 is offline
Old July 25th, 2011, 01:05 PM
Kjr442
kjr442's Avatar
Thanks, I do appreciate that.
kjr442 is offline
Old July 25th, 2011, 01:08 PM
69442C's Avatar
Anytime. And tell us your first name.
Brian
69442C is offline
Old July 25th, 2011, 01:28 PM
TK-65's Avatar
I guess I dont get what Im looking at, whats wrong with what he did?
TK-65 is offline
Old July 25th, 2011, 01:33 PM
Kjr442
kjr442's Avatar
Brian
The name is Kevin, pleased to meet you Brian.
kjr442 is offline
Old July 25th, 2011, 01:40 PM
69442C's Avatar
Thanks Kevin and same here.
I think I saw on another one of your posts where you were asking for any suggestions on your project and I would like to offer one. If you can find one, plant a money tree in your back yard and fertilize the heck out of it!!
69442C is offline
Old July 25th, 2011, 01:44 PM
Kjr442
kjr442's Avatar
Not much I guess. From the responses I have had on this, what he did is perfectly acceptable. I had always wanted to replace the quarters completely all the way to the factory seams,that is why I bought the full quarters. The quarter was cut below the drip rail.
kjr442 is offline
Old July 25th, 2011, 01:50 PM
Rickman48's Avatar
I'm glad you're happy with the explanations!
The 'failure to communicate' part is probably because the 'salesman' you talked to probably never did bodywork, or mounted a body to a rotisserie, and doesn't understand the proceedure himself.
You'll be super happy with the outcome!
Old July 25th, 2011, 01:52 PM
Kjr442
kjr442's Avatar
Thanks Brian,(Ha Ha) that's real helpful. I wish I could, this thing is a money pit for sure!
kjr442 is offline
Old July 25th, 2011, 02:11 PM
Kjr442
kjr442's Avatar
Well,the salesman is the owner. I think he is a very accomplished body man.His brother works for him, and is unbelievably good. The big problem here is the lack of communication between him and his other men. The owner and his brother went on vacation, and left the shop in the hands of the workers. I was not told that my car had been started on,or that it was vacation time.
I made a surprise visit, and this is what I walked in on. After reading some of the responses here, I am not as mad now. Thank you.
kjr442 is offline
MDchanic
Non-Olds Engines
17
May 23rd, 2013 08:20 PM
joe_padavano
March 5th, 2013 05:26 PM
Blackpage
January 23rd, 2013 06:32 PM
MDchanic
November 3rd, 2010 12:48 PM
don71
March 23rd, 2008 02:27 PM
Quick Reply: Whats wrong with this picture?
