OK, I see what these numbers are. My question is and I know I have seen it before that the vin number would be here. Where is the Vin number stamp at on the frame or should it be?
Should be generally in area where 'oldoldss' example shown.
While mine is a '69 it is more forward of the example, and more on 'vertical' portion of frame and not on top like the post example.
Presuming area differed a bit between 69 & 72...
3992389 is the part number for a 1968-72 Olds A-body convertible frame.
The S in a circle designates A.O. Smith manufacturer.
370 is a control number.
7 14 is July 14th. There should be a shift and assembly line code after that but I can't read them. The CS is an application suffix that should correspond to the frame code on the build sheet..
