What are these numbers on my 71 cutlass convertible frame?
Old Jun 7, 2026 | 10:37 AM
kelly bakies's Avatar
What are these numbers on my 71 cutlass convertible frame? They do not match my Vin number and I am very curious Are they just a part number?
Old Jun 7, 2026 | 11:16 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Does it align with the VIN?
Old Jun 7, 2026 | 11:31 AM
Vin number
OK, I see what these numbers are. My question is and I know I have seen it before that the vin number would be here. Where is the Vin number stamp at on the frame or should it be?
Old Jun 7, 2026 | 12:00 PM
oldoldss's Avatar
Look on the top of the frame about where the drivers' door would be above.
See an example on this thread: https://classicoldsmobile.com/forums...d-frame-41249/
Old Jun 7, 2026 | 12:45 PM
I see nothing on the frame in those areas. Body is not on the frame
Old Jun 7, 2026 | 01:00 PM
1969Hurst's Avatar
Should be generally in area where 'oldoldss' example shown.
While mine is a '69 it is more forward of the example, and more on 'vertical' portion of frame and not on top like the post example.
Presuming area differed a bit between 69 & 72...
Old Jun 7, 2026 | 01:54 PM
still nothing. maybe someone has a 71 convertible that would give me better lead. thanks
Old Jun 8, 2026 | 01:12 PM
3992389 is the part number for a 1968-72 Olds A-body convertible frame.
The S in a circle designates A.O. Smith manufacturer.
370 is a control number.
7 14 is July 14th. There should be a shift and assembly line code after that but I can't read them. The CS is an application suffix that should correspond to the frame code on the build sheet..
Old Jun 9, 2026 | 03:32 PM
Jungle Cat's Avatar
Surprised it took so long for someone to give correct information
Old Jun 9, 2026 | 10:08 PM
Charlie Jones's Avatar
Phantom Phixer
It takes a while sometimes for Joe P to read every post.
Old Jun 10, 2026 | 11:06 AM
Jungle Cat's Avatar
I have always found the VIN stamped on top of the frame right where the drivers door is. Look harder. My GSX was stamped twice there.
Old Jun 14, 2026 | 08:32 AM
I've been on Power Tour all week and not exactly keeping up with the interwebs.
Old Jun 14, 2026 | 08:35 AM
It appears Smokin' Joe, rocket scientist and aero engineer, has returned to us, despite the wrecks, thefts, and breakdowns commonly found on the Tour.
Old Jun 14, 2026 | 08:45 AM
Eight days, ten states, 2,900 miles, and a few thousand dead bugs later.
6t9chgr
Nov 14, 2024 02:42 PM
bkeese
Feb 13, 2020 01:59 PM
TripDeuces
Jul 12, 2019 05:15 PM
JOHNNYOLDS442
May 2, 2018 10:15 AM
Jimoldsfan
Aug 9, 2015 02:40 PM
