Can I remove this?
Can I remove this?
Jul 29, 2018 | 01:10 PM
johnrossjdr
Aug 2017
Bay Area, CA
Can I remove this?
72 cutlass supreme, assuming this is left over from gutted a/c, ok to remove and just connect the hose? Replacing radiator as found a pinhole leak.
johnrossjdr
Find More Posts by johnrossjdr
Jul 29, 2018 | 01:11 PM
johnrossjdr
Aug 2017
Bay Area, CA
Better pic hopefully
johnrossjdr
Jul 29, 2018 | 01:26 PM
brandon reynolds
Jan 2010
hatfield PA
That looks like an aftermarket transmission cooler. You could just hook the lines up to your new radiator if you buy a radiator with a cooler in it.
brandon reynolds
Find More Posts by brandon reynolds
Jul 29, 2018 | 02:10 PM
oldcutlass
Oct 2009
Poteau, Ok
Or you can keep using it if it does not leak. One line should go to or from the radiator, the other to the trans.
oldcutlass
Find More Posts by oldcutlass
Jul 30, 2018 | 07:26 AM
johnrossjdr
Aug 2017
Bay Area, CA
Thanks guys! Appreciate the help as always.
johnrossjdr
question about radiator - 1978 Toronado
jaunty75
Jul 10, 2017
03:04 PM
New radiator steel straps
455man
05:43 PM
i just noticed that my transmission lines dont run into the radiator
4door!cutlass
07:16 AM
Suitable Replacement Radiator on my 84' ?
HurstLightning84
Hurst/Olds
09:32 AM
*** Radiator Emergency *** Please Help
help442onguam
Jun 24, 2012
07:00 PM
Wot
04:50 AM
