Can I remove this?
Old Jul 29, 2018 | 01:10 PM
johnrossjdr's Avatar
Can I remove this?
72 cutlass supreme, assuming this is left over from gutted a/c, ok to remove and just connect the hose? Replacing radiator as found a pinhole leak.
Old Jul 29, 2018 | 01:11 PM
Better pic hopefully
Old Jul 29, 2018 | 01:26 PM
brandon reynolds's Avatar
That looks like an aftermarket transmission cooler. You could just hook the lines up to your new radiator if you buy a radiator with a cooler in it.
Old Jul 29, 2018 | 02:10 PM
Or you can keep using it if it does not leak. One line should go to or from the radiator, the other to the trans.
Old Jul 30, 2018 | 07:26 AM
Thanks guys! Appreciate the help as always.
jaunty75
Jul 10, 2017 03:04 PM
455man
Apr 20, 2014 05:43 PM
4door!cutlass
Mar 27, 2014 07:16 AM
HurstLightning84
Hurst/Olds
Aug 24, 2012 09:32 AM
help442onguam
Jun 24, 2012 07:00 PM
