W30 aluminum intake
I know the stamping on the 70 is there a difference and the later stamping is also on the 71/72 I believe ? (Not 💯 on that ) is there a performance difference ? My 71 442 was march of 71 so A few things are dated 70. Is there a performance difference ?
1. Edelbrock RPM Air Gap with 1970 Chevelle Cowl Induction (CI) adapter on your air cleaner base. Use W-30 foam on the CI adapter.
2. Crosswind with CI adapter and W-31 foam.
3. Performer with CI adapter and W-30 foam.
4. Torker with CI adapter and W-31 foam.
Also, with any of these, you will need to fabricate longer vent pipes from valve cover breather to air cleaner elbow.
yellowrocket
March 25th, 2019 02:22 PM
