W30 aluminum intake
Old Apr 3, 2022 | 03:34 PM
pnagy23's Avatar
W30 aluminum intake
Is there any differences between a 70 w30 aluminum intake and a 71/72 w30 aluminum intake ?
Old Apr 3, 2022 | 03:58 PM
70W-32's Avatar
There are 2 70 intakes, and 1 71-72 intake
Are you asking about performance, or part numbers and appearance?
Old Apr 3, 2022 | 05:32 PM
pnagy23's Avatar
I know the stamping on the 70 is there a difference and the later stamping is also on the 71/72 I believe ? (Not 💯 on that ) is there a performance difference ? My 71 442 was march of 71 so A few things are dated 70. Is there a performance difference ?
Old Apr 4, 2022 | 07:46 AM
70W-32's Avatar
No difference in performance. They are just an aluminum copy of the cast iron intake. And a March 1971 car is relatively a late build. Production of 1971 models started in August of 1970
Old Apr 4, 2022 | 08:46 AM
pnagy23's Avatar
What would you suggest for performance then ? That will still work with my hood and air cleaner in aluminum?
Old Apr 4, 2022 | 03:06 PM
70W-32's Avatar
What is done to the motor?
Old Apr 4, 2022 | 03:26 PM
pnagy23's Avatar
Haven’t stated on the motor yet. Only going to do a little head work. Maybe bore intake a little. Upgrade cam. mostly stuck is what I want. Would like 400hp nothing crazy
Old Apr 4, 2022 | 03:43 PM
VC455's Avatar
Barely Registered
Originally Posted by pnagy23
What..performance (aluminum intake) will still work with my hood and air cleaner...?
You have a few options. But none will allow you to keep the iconic OAI adapter with the flapper door.
1. Edelbrock RPM Air Gap with 1970 Chevelle Cowl Induction (CI) adapter on your air cleaner base. Use W-30 foam on the CI adapter.
2. Crosswind with CI adapter and W-31 foam.
3. Performer with CI adapter and W-30 foam.
4. Torker with CI adapter and W-31 foam.
Also, with any of these, you will need to fabricate longer vent pipes from valve cover breather to air cleaner elbow.
twillis004
Jul 27, 2019 09:49 AM
yellowrocket
Mar 25, 2019 02:22 PM
1970442
Feb 7, 2016 06:29 AM
joesw31
Oct 18, 2015 09:26 AM
stevengerard
Feb 17, 2012 06:44 AM
