Special Order Paint Color Cars
Old August 16th, 2021 | 03:15 PM
I have asked this question in posts that weren't about that a question. Maybe Joe or someone else can verify or squash it.
I thought I had read years ago that all special order paint color cars came out of Lansing. Am I incorrect in that?
Old August 16th, 2021 | 04:06 PM
Not true. There are documented special paint cars from other plants.
Old August 16th, 2021 | 05:23 PM
Ok cool. Thanks for that info.
I have also thought all W cars were Lansing built until 72. Is that correct?
Old August 16th, 2021 | 05:26 PM
W30s and W31s were Lansing built only because of the select-fit engines. The others (W32, W33) didn't get the select-fit parts and were available from other plants. Of course, since Toros were only built at Lansing in those years, W34s only came from Lansing.
Old August 17th, 2021 | 06:10 AM
rand5204's Avatar
My special order paint (Viking Blue) 70 442 was built in Fremont, CA. The build sheet even has "Special Pain" typed on it.
Old August 17th, 2021 | 06:59 AM
rocketraider's Avatar
Oldsdruid
Code 26 Viking Blue was a Toronado-only color in 1970, so that explains your build sheet.
If you'd seen the tech bulletins issued on matching Code 26 blue during collision repair you'd realise "Special Pain" is a pretty accurate description for that color!😃
Old November 14th, 2021 | 09:09 AM
body 51's Avatar
Here is my build sheet
Linden NJ
File Type: pdf
Old November 14th, 2021 | 09:38 AM
Bigmikey65's Avatar
Don’t want to hijack the post. Anchor Motor Freight is printed on the bottom of body 51s build sheet. I Googled the former company and found an interesting historical article in the December 2011 issue of Hemmings. Sorry - I could not paste it.
Old November 14th, 2021 | 10:00 AM
Linden NJ
Boy your car is loaded. Is there a thread somewhere here on it? I couldn't seem to find one.
Old November 14th, 2021 | 02:42 PM
body 51's Avatar
no sir
I have never published much of anything about the car on the site
File Type: pdf
Old November 14th, 2021 | 03:55 PM
lunaboy's Avatar
The Rocket Astronomer
to expand on the question : Did the cars that out came out of Lansing all have the - - dash dash for special order paint and the did the cars out of say Fremont, CA. have the actual two digit code .
Old November 14th, 2021 | 03:59 PM
The "- -" code was supposed to be used for special order paint at all plants. As the model year went on, some plants started stamping the two digit code for the four "special order" colors. Do not confuse those "extra cost" colors with true special order paint cars that used non-Olds or even non-GM colors. This was an option under RPOs Y62, Y63, Y66, and Y76 special order paint options. Those always had a "- -".
Old November 14th, 2021 | 11:55 PM
hurst68olds's Avatar
here's the tag from a '67 442 I used to own that had Toronado ONLY "emerald green metallic" paint (paint code "J" for Toronado & Buick)
the "L62G052" format numbers are listed in the assembly manuals (but, the "J" paint code is not listed in the F85 manual) - I believe the LX-146 is the sequential "special paint" vehicle at Lansing number or similar
some of the '70 Linden NJ "special paint" cars have a "Wxxxx" FISHER "W" number format paint code, I believe those are listed in the assembly manual also
Old November 15th, 2021 | 04:33 PM
body 51's Avatar
Here is the tag on my Linden NJ built 442
it does not show the - - but has the paint code WA 3893 Which is also on the Build sheet along with the Y 62 Special Paint change
Old November 15th, 2021 | 08:43 PM
You should share your car here.
Old November 15th, 2021 | 10:15 PM
....... along with the Y 62 Special Paint change
I'd bet that's CHARGE as in extra $$$$$
Old November 16th, 2021 | 05:31 AM
From 1970:
Old November 16th, 2021 | 06:36 AM
allyolds68's Avatar
This 68 Cutlass was Oshawa built with a Pontiac paint code Q-Q Verdoro Green
http://www.oldsmobilecentral.com/for...l-tag-info.php
Cutlass Fan
Paint
November 2nd, 2020 03:53 PM
November 17th, 2012 06:12 PM
HiCompOlds
Paint
February 5th, 2012 06:02 AM
cutlassgal
May 28th, 2010 09:08 AM
317rcampbell
Paint
December 2nd, 2009 02:17 PM
Quick Reply: Special Order Paint Color Cars
