Smog Emissions help
Old Nov 6, 2009 | 02:29 PM
Jolly Green's Avatar
Exclamation Smog Emissions help
Hey guys, I need some help for a friend of mine.
He's got a 69 Camaro (I know, I know) 350, 10:1 compression and he's trying to register in Nevada. Fails smog check. They've leaned out the fuel all the way. It passes the 2500 rpm but not the idle test. One miss and it floods the tubes. He's running 91 octane right now, would going lower or higher octane help him? He has no catalytic converters. The aggressive cam seems to be the problem. Can't register it in another state, unfortunately.
Tricks of the trade? We've tried to think outside the box as far as cutting holes in the exhaust to let some gas escape or trying to make a system that will force outside air thru the pipe, or me having to flirt with the guy running it while my buddy kicks the probe out, haha. Please, I don't look good in drag!
Old Nov 6, 2009 | 03:54 PM
wolfman98's Avatar
Captain of my ship
have you considered an addative for the fuel to try to pass the test. I have seen more than one that guarentee it will work to pass the car. maybe check around your local auto parts or NAPA dealer?
Old Nov 7, 2009 | 12:13 PM
Nevada requires a FOURTY year old car to be tested?????
Is the car original? If not, what's been done to it? Most states have a waiver limit if the car is stock with all emissions equipment in place.
By the way, cutting holes in the exhaust is not a good idea for two reasons. First, the new emissions test units can measure dilution of the exhaust, which is grounds for failure. Second, since the emissions tests measure either percentage or parts per million, it doesn't matter if you cut holes, the PPM and % remain the same.
Old Nov 8, 2009 | 04:34 AM
wolfman98's Avatar
Captain of my ship
Joe raised a good point here about exemptions for older cars. maybe you should check into antique status of your car? Most states and provinces consider any vehicle over 30 years old as an antique and if registered as such is exempt from emissions testing or at least has relaxed standards.
Old Nov 8, 2009 | 09:47 AM
mugzilla's Avatar
is Fast Enough ...
Set idle as fast as you can ...
Wolfman is right about additives, follow directions...
Fresh oil ..?
what timing..? vacuum advance ?, make sure you are on the right port ...
temp ..?
The easiest thing to do is go to Pep Boys and hunt up a mexican "Smog Mechanic"
Old Nov 8, 2009 | 02:42 PM
BOOWAH's Avatar
Emissions Test
I found a sure cure for passing the emissions test. It's called "Antique Plates" For a one time fee of 60 bucks....no more inspections period, as well as no annual registration fee! Emissions testing is rediculous anyway. Do they test commercial vehicles?.....NO. Do they let you buy credits from new vehicle owners to apply to your smog burner?......NO When this country gets serious about CO2 emissions, then I'll get serious!
Old Nov 9, 2009 | 05:49 AM
I agree with the others. You should investigate registering the car as an antique vehicle. I find it amazing that this car requires emissions testing in the first place.
Old Dec 4, 2009 | 03:09 AM
64Super88's Avatar
Rich from Las Vegas
Nevada has a cut off of 1967 /1968 for emissions... 67 your good, 68 your screwed...
Try a place called Silver State Speed Shop off Charleston and 95... 366-1212
Old Dec 4, 2009 | 03:17 AM
Wasted's Avatar
Arizona as that exact same rule. I was surprised when they told me to go to emissions to get the 70 registered.
1978 Oldsmobile Omega
Aug 21, 2014 07:30 AM
2blu442
May 3, 2014 09:55 AM
leepear
Dec 1, 2011 04:00 AM
2blu442
Feb 24, 2008 07:07 AM
The Pope
Jul 27, 2007 01:09 PM
