Need a little help - Transmission Fluid
I hope that someone with this era of car will chime in.
Pat
The transmission fluid is checked and filled through the dipstick filler tube . This should be located on the lower passenger side (right) of the engine, kinda back in a hole and may be a little hard to see at first. I use a flexible funnel and that seems to help in getting the fluid in the transmission and not all over the car.....Tedd
my 49 has a hole in the floor above the plug/dipstick, to check and add trans fluid to. while we are on old trans, what fluid is compatible with the older units? my manual says in an emergency i can use 20 wt non detergent oil, but only temperary. what is correct to refill with?
http://chevy.oldcarmanualproject.com...4655hmt16.html Try this link it shows both the earley and late versions of the hydramatic.....Tedd
Thank you.
A dipstick seems to be a better idea, I guess it was a manufacturing cost cutting move to just have a plug.
Roger.
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
henryk8398
Ninety-Eight
January 24th, 2009 07:49 AM
