70 GM Fuel Tanks - Cutlass, Chevelle GTO
Old Jul 1, 2014 | 04:19 AM
Del70's Avatar
Are the fuel tanks and the sending unit for a w/o fuel line return system, used in the 70 Chevelle, 70 Pontiac GTO/Tempest, 70 Buick Skylark the same tanks used in the 70 Cutlass tank.? I have a large parts restoration supplier in my area that sells them for Most GM makes, but of course they do not sell Cutlass parts. If the 70 GM tanks are the same, I can just pick one up from them.
thanks
Old Jul 1, 2014 | 05:15 AM
Originally Posted by Del70
[SIZE=3]Are the fuel tanks and the sending unit for a w/o fuel line return system, used in the 70 Chevelle, 70 Pontiac GTO/Tempest, 70 Buick Skylark the same tanks used in the 70 Cutlass tank.?
Far as I know.
Is there something special about their tanks? Because many users here have used Spectra tanks from RockAuto or the local auto parts store for something like $150, if I recall (those who have bought them can correct me).
Old Jul 1, 2014 | 05:55 AM
66400's Avatar
One issue with swapping a 70 Cutlass fuel tank with a 70 Chevelle fuel tank is the length and indexing of the filler tube. The tank is the same but filler tube design keeps it from being an interchange.
Henry
Old Jul 1, 2014 | 06:16 AM
11971four4two's Avatar
MOTORHEAD
autocity classics 800-828-2212 has cutlass fuel tanks
Display # Results 1 - 11 of 11
Old Jul 1, 2014 | 09:03 AM
Del70's Avatar
thanks. Great reminder about the neck length/angle differences...I will just look for and order one that is correct for a 70 Cutlass...thanks
Old Jul 1, 2014 | 09:12 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
caveat emptor all Thailand....Spectra Quantum Canadian.
Old Jul 13, 2014 | 03:13 PM
Del70's Avatar
Seems most of the new tanks are 17 gallon not the 20 gallon they should be. So if you pick up a 17 gallon tank, will the factory straps still work or do you need straps for a these 17 gallon tanks. ( I am assuming the tank width is different)
Has anyone purchased one of the 20 gallon tanks from the supplier mentioned above, how are they?
thanks
Old Jul 14, 2014 | 06:41 AM
Boiler_81's Avatar
Amazon sells the Spectra tanks. If you have Prime, it's a great deal with the free shipping.
thanks
Del70
Sep 10, 2014 04:53 AM
Del70
Jul 17, 2014 05:43 PM
BeenThere
Apr 22, 2013 09:52 AM
