Need Help Deciphering
Old Feb 24, 2013 | 08:09 AM
sleeton's Avatar
I went and looked at a 72 cutlass convertible unfortunately in the dark. that aside the engine code is 396921 and the heads had a large C on them. Owner says it is a 455. Does this decode out as a 455
Old Feb 24, 2013 | 11:12 AM
rcorrigan5's Avatar
Randy C.
The block number checks out to be a 455. The "C" on the heads doesn't, though - they check out to be for the 400 engine 67-69. It could be what you really saw was a "G" or a "big captial G little captial A" which would be 445 heads for 71 and 72, respectively.
Randy C.
Old Feb 24, 2013 | 11:59 AM
Octania's Avatar
"C" heads were used on ALL the run of the mill BB's 1967 thru 1969.
Only 68-9 W30 400 and most 455 '68 H/O's and all 455 '69 H/O's got the other available letter those years- "D"
Agreed that the '71 should have G heads, which resembles a "C" in the dark. To help verify, look for the 6-digit [3 and 3 on each side] adjacent to the center lower rocker cover bolt.
C- 394548
G- 409100
The 396021 block is a 455 anywhere from '68 to '76.
Old Feb 24, 2013 | 02:48 PM
As Chris correctly points out, the C heads were used on 455s for the 1968-69 model years. Check the VIN derivative stamp on the block, but if the heads are original to the block, this is a 68-69 455.
JW1
Mar 14, 2013 06:12 PM
Blackpage
Mar 14, 2013 01:52 PM
Blackpage
Sep 13, 2011 04:15 AM
getawaycar
Apr 25, 2011 12:42 PM
