Just wondering 🤔
Just wondering 🤔
As many of you know (or may not know), I found the build sheet for my '72 U code Supreme tucked under the driver seat when I had it re-upholstered. Due to the delicate nature of the document, and the fact that it was in such good condition after 50 years, I immediately decided to laminate it to keep it preserved. I also have it "backed " with a sheet of plain white paper just for good measure.
What's done is done, but I sometimes wonder if I maybe affected the originality and should have taken a different route and maybe just put it in a clear sheet protector ? 🤔
Thoughts?...
Thoughts?...
x2
Preserving documents the proper way can have a drastic effect on their longevity. This could at least have a small effect on the eventual selling price of your Oldsmobile. Especially, if it's highly desirable or went through a concours restoration.
The proper way???...not sure what you mean.
Hopefully you didn't damage the build sheet by laminating it. Did you adhere the sheet of paper to the back of it? Putting it in a document protector would have been the least intrusive way to preserve it.
I have my window sticker in an archival sleeve tucked away. My concern would be the acidity of the white paper that you used as backer, as it can degrade your build sheet. Laminated as it is may negate deterioration as outside air would be sealed out.
As to devaluing it - Hmm...
