Just wondering 🤔
Old Aug 11, 2022 | 07:36 PM
72455's Avatar
1972 U code Supreme
Just wondering 🤔
As many of you know (or may not know), I found the build sheet for my '72 U code Supreme tucked under the driver seat when I had it re-upholstered. Due to the delicate nature of the document, and the fact that it was in such good condition after 50 years, I immediately decided to laminate it to keep it preserved. I also have it "backed " with a sheet of plain white paper just for good measure.
What's done is done, but I sometimes wonder if I maybe affected the originality and should have taken a different route and maybe just put it in a clear sheet protector ? 🤔
Thoughts?...
Old Aug 11, 2022 | 07:37 PM
I think you are overthinking it.
Old Aug 11, 2022 | 07:50 PM
72455's Avatar
1972 U code Supreme
Am I?...cuz I was wondering the same thing. That's the point of my question.
Old Aug 12, 2022 | 06:00 AM
BackInTheGame's Avatar
I would have just put it in a sheet protector. But that is probably because I don't have quick/easy access to a laminator As to devaluing it - Hmm...
Old Aug 12, 2022 | 06:18 AM
x2
Preserving documents the proper way can have a drastic effect on their longevity. This could at least have a small effect on the eventual selling price of your Oldsmobile. Especially, if it's highly desirable or went through a concours restoration.
Old Aug 12, 2022 | 06:23 AM
I'd have put it in a sheet protector, as well. I'll say this though - make certain it never sees exposure to sunlight (UV). Store it in the dark.
Old Aug 12, 2022 | 07:00 AM
72455's Avatar
1972 U code Supreme
No worries there Norm...it's locked up in my safe 😁
Old Aug 12, 2022 | 07:05 AM
72455's Avatar
1972 U code Supreme
Originally Posted by Olds64
x2
The proper way???...not sure what you mean.
Old Aug 12, 2022 | 07:19 AM
Document preservation is a damn sight easier when said document hasn't spent the first 50 years of its existence jammed between the springs in a seat cushion.
Old Aug 12, 2022 | 07:26 AM
Hopefully you didn't damage the build sheet by laminating it. Did you adhere the sheet of paper to the back of it? Putting it in a document protector would have been the least intrusive way to preserve it.
Old Aug 12, 2022 | 07:49 AM
Dave - You probably want an airtight (hermetically) sealed safe capable of storage at Zero Kelvin - e.g. zero movement of any atom. 😵‍💫😵‍💫😵‍💫
Old Aug 12, 2022 | 07:55 AM
72455's Avatar
1972 U code Supreme
Didn't adhere it...just laminated them together.
Old Aug 12, 2022 | 11:02 AM
70W-32's Avatar
As long as it is legible, I dont think youve done anything wrong.
Old Aug 12, 2022 | 11:14 AM
Dang, it’s just a build sheet, not the Magna Carta.
Old Aug 12, 2022 | 12:10 PM
oldolds88's Avatar
put my build sheet for my one owner nova in the cabinet in the garage,when i went to get it,it was mouse food, years ago
Old Aug 12, 2022 | 01:22 PM
Mine are in a sheet protector in a binder sealed in a Rubbermaid tote. And those are just IBM trim cards, POP and VVS paperwork. No build sheet 'cause we're talking Lansing here.
Old Aug 12, 2022 | 02:15 PM
I have my window sticker in an archival sleeve tucked away. My concern would be the acidity of the white paper that you used as backer, as it can degrade your build sheet. Laminated as it is may negate deterioration as outside air would be sealed out.
Old Aug 12, 2022 | 05:02 PM
Having watched several episodes of Antiques Roadshow, I think I can say with some authority that lamination is usually a bad idea.
Old Aug 13, 2022 | 05:14 AM
Bfg's Avatar
Bfg
If you wanted to retain originality, you should stuff it back under the seat where it was placed in the first place! And perhaps take a picture of it while under seat and frame the picture.
Nov 26, 2020 07:13 PM
GreatSX
Nov 20, 2020 09:31 AM
ostricker
Apr 19, 2019 10:50 AM
sammy
Nov 5, 2013 09:17 PM
rrielley
Jan 29, 2008 03:13 PM
