Help me make the Transmission Decision
Old May 14, 2009 | 07:30 AM
morrowjm4154's Avatar
I have my 455 freshly rebuilt and now I need some experienced help on which transmission I need to mate up to the motor to be the meanest and work best for me. I plan on making sure that I can outrun (if need be) any body who wants to try and test the Olds power. I have a TH350 that I had mated up to the 403 I pulled and I also have a TH400 that I pulled with the 455. Which one would be the best choise to put back into my 71 Cutlass. I am split becuase I have so many people tell me different things and I honestly have no clue when it comes to the right Transmission to use. Please help me out and give me your thoughts.
Old May 14, 2009 | 08:25 AM
citcapp's Avatar
I have a preference for the 400 as it is a stronger tranny in it's stock congfigeration and less costly to build up. The 350 is lighter and uses less hp and can be built to work behind the 455, just costs a litte more at least around here it does. It mostly comes down to personal choice. You'll get different opinions on this I'm sure
Old May 14, 2009 | 09:44 AM
Unless the TH350 is custom built to handle the torque, I'd go with the TH400. That's what the factory used. The differences in internal friction, etc, that people talk about are only measurable on the drag strip.
Old May 14, 2009 | 11:17 AM
Texascarnut's Avatar
Geezer
Use the TH400. The TH350s were/are transmission shop Queens on the best day they ever had or will ever have.
Old May 14, 2009 | 01:23 PM
kaz442's Avatar
TH-400 no question. JKaz
Old May 14, 2009 | 05:18 PM
Vinny72olds's Avatar
Go with the 400. It's better equipped to handle the torque.
Old May 14, 2009 | 06:13 PM
jensenracing77's Avatar
i agree with joe. i have seen built up TH350 hold up to a modified 455 but they had many dollars in that TH350. the 400 is cheeper to build around my area also.
Old May 14, 2009 | 08:08 PM
Thank you all, but now the next question
Thank you all so much and I will go with the TH-400. The next question is this, will the drive line that was used with the TH-350 still be used with the Th-400 or will I have to change out yokes, shorten the the drive shaft or anything else that may be really surprising when I do this. Once again, thank you all for the help.
Old May 15, 2009 | 03:46 AM
yammiman's Avatar
Not sure about the yokes but the length should be fine - you might want to beef up the u-joints!
Old May 15, 2009 | 06:45 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
you will have to change yokes for sure.
Old May 15, 2009 | 09:59 AM
Thanks again
Old May 15, 2009 | 10:43 AM
RAMBOW's Avatar
Ben
TH400, i really hate the TH350 TV cable crap.
Old May 15, 2009 | 11:48 AM
"Survey says"
TH400
Old May 16, 2009 | 01:04 AM
mugzilla's Avatar
is Fast Enough ...
Who has the beefiest u-joints ..?
Old May 16, 2009 | 06:47 AM
Run to Rund's Avatar
Strongest and meanest? Jerico.
Old May 16, 2009 | 08:48 AM
I never use mine. Broke the cable and never bothered putting another on.
If you mess up the cable on a later trans you're in trouble.
but old 350's.... no big deal.
Old May 19, 2009 | 07:40 PM
mugzilla's Avatar
is Fast Enough ...
thanks ...
Old May 19, 2009 | 07:49 PM
Redog's Avatar
400, no question
shawnsds
May 21, 2013 10:48 AM
69442
Oct 5, 2011 05:50 PM
rayfrausto
Sep 17, 2011 12:05 PM
sszewczuk
Apr 2, 2011 03:45 PM
