Fuel additive
Old June 26th, 2015, 06:27 AM
67Rocket's Avatar
Fuel additive
Do those of you who still run original engines without "hard" valve seats use any additives in your gas? If so, what do you use?
67Rocket is offline
Old June 26th, 2015, 06:56 AM
No, its not required. The seats don't wear much with todays fuel. You have to remember that the lead was added for the anti-knock characteristics and the bonus benefit was it somewhat coated the seats.
oldcutlass is offline
Old June 26th, 2015, 07:42 AM
D. Yaros's Avatar
I don't often use a fuel additive, but when I do, I use TEL!
D. Yaros is offline
Old June 26th, 2015, 09:00 AM
Ozzie's Avatar
I have four "antiques" with original engines currently. I don't use any fuel additive for the valves and, so far, there have been no valve problems.
Ozzie is offline
Old June 26th, 2015, 09:04 AM
chip-powell's Avatar
No additives for me. I just run 93 octane and have no knocks or problems in the last 2 plus years.
chip-powell is offline
Old June 27th, 2015, 08:02 AM
sammieolds's Avatar
I never run any additives ,Do you run Enthole free or reg 93 octane
Steve
sammieolds is offline
Old June 28th, 2015, 04:03 PM
Tedd Thompson's Avatar
I just run pump gas in my 327 Chevy powered Land Cruiser and have from the time we couldn't get leaded fuel sometime in the seventies. Probably 40,000 miles with no problems...Tedd
Tedd Thompson is offline
Old June 29th, 2015, 08:52 AM
tds
tds's Avatar
I used Octane Supreme until I had the engine rebuilt. Not sure it needed it, but I did not have any problems. Since rebuild, I just use 93 at the pump. No problems.
tds is offline
Old June 29th, 2015, 09:23 AM
morgan
pogo69's Avatar
driving habits play into this for sure. my take is if your running it hard the valves will sink quicker without that little bit of lead. if your a moderate driver it shouldnt be a problem with unleaded
pogo69 is offline
Old June 29th, 2015, 10:28 AM
I use no additive now.
Before I polished the combustion chambers I used Octane Supreme (tetraethyl lead / TEL) to increase the octane, but don't need it now.
MDchanic is offline
Old June 29th, 2015, 04:31 PM
Bfg
Bfg's Avatar
I have used a pint of transmission fluid to a tank of gas. This is something I learned from my Grand Pappy many moons ago.
Bfg is online now
stirlingguy
September 2nd, 2013 03:31 AM
dads66cutlass
July 24th, 2011 10:54 AM
Dan Wirth
October 3rd, 2009 10:53 PM
AZ442
September 23rd, 2009 07:16 PM
Col Wickham
August 29th, 2009 10:43 PM
Quick Reply: Fuel additive
