Freeze Plugs Theft Ring
Old October 25th, 2022, 05:10 PM
Oldscarnut
Chuck Cole's Avatar
Arrow :p
Chuck Cole is offline
Old October 26th, 2022, 05:26 AM
If the freeze plugs were missing coolant would pour out of the block just as fast as you poured it in. Is it just leaking/dripping? Ask the shop if they know anything about it.
Olds64 is offline
Old October 26th, 2022, 05:53 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
WTF? What are your current temps in Ontario? Did the freeze plugs actually work? A freeze plug kit is like $20, why would someone pull them out?
olds 307 and 403 is offline
Old October 26th, 2022, 06:06 AM
Proud Viet Nam Veteran
redoldsman's Avatar
How would somebody pull the freeze plugs out without destroying them? This is strange. I will stay tuned.
redoldsman is online now
Old October 26th, 2022, 08:58 AM
The proper name for a "freeze plug" is core plug. The intended purpose of the plugs is to fill the holes in the block after the casting sand is removed. An unintended benefit is they may (50/50 chance) push out in case of the coolant freezing to prevent the block from cracking. If they did push out they would have been on the floor under the engine.
oldcutlass is online now
Old October 26th, 2022, 09:18 AM
bccan's Avatar
I think they’re in cahoots with South Park’s underpants gnomes
bccan is offline
Old October 26th, 2022, 04:51 PM
Tedd Thompson's Avatar
I’ve seen a bunch of freeze plugs pushed out, but never all six at the same time ? And I think a 50/50 chance of them saving a block is, at best, optimistic. I don't know what happen, but I smell fish...Tedd
Tedd Thompson is offline
Old October 26th, 2022, 07:13 PM
MO Olds 2022's Avatar
To your first question, if you don't have an engine hoist anymore you might be able to use/rent an install kit to get them in or at least started.
Freeze plug installation kit
MO Olds 2022 is offline
Old October 26th, 2022, 07:48 PM
Oldscarnut
Chuck Cole's Avatar
Old October 27th, 2022, 05:35 AM
Since you don't have a hoist you might be able to unfasten the motor mounts and support the engine with some 4x4s cut down. I'm thinking under the oil pan and you might have enough clearance.
Olds64 is offline
Old October 31st, 2022, 05:27 AM
Good to hear you got the freeze plugs installed. 4 hours of prep work for a 5 minute job sounds about normal.
Olds64 is offline
Nop
June 28th, 2014 05:02 AM
72CUTTY
March 26th, 2012 08:46 PM
Gunfreak25
December 24th, 2010 09:49 PM
TheRuss
April 13th, 2009 01:03 PM
wagonman
March 7th, 2008 06:49 AM
Quick Reply: Freeze Plugs Theft Ring
