Car Quits When Headlights Turned On
Old Oct 29, 2022 | 05:25 AM
F-85 4-4-2's Avatar
My '66 4-4-2 starts right up, even after sitting for weeks, but the first time that the headlights are turned on, it quits. It won't start again immediately, acts like a totally dead battery, but 15 seconds later, fires like nothing ever happened. You can then on-off the headlights without issue. Battery, battery terminals, cables, alternator, starter all good. Could a bad voltage regulator be the culprit? Or?
Old Oct 29, 2022 | 05:46 AM
Yes VR could be going bad. I'm not sure where your VR obtains its ground - often the VR is attached to chassis metal (firewall?) to gain it's ground. Might check VR connection is clean.
Old Oct 29, 2022 | 05:50 AM
What is the voltage at the battery with the engine running.
Old Oct 29, 2022 | 09:37 AM
F-85 4-4-2's Avatar
14V immediately after starting, after running a few minutes, settles at 13.1V.
Old Oct 31, 2022 | 09:33 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
13.1 is very weak. Thats 0.5 VDC off the surface charge on the battery.
14.0-14.2 is normal.
Grounds Grounds Grounds!!! Find 'em, clean 'em, spary 'em with battery protenant.
Do you know how to test an external VR? Don't just replace it.
Could be the diode bridge in the alternator failing.
Load test the alternator and the battery (if you're suspicious of the battery).
Oh did I mention verify all grounds?
Old Oct 31, 2022 | 10:05 AM
Here's some great advice on how to troubleshoot alternators & regulators.
I can not the credit. One is from Harvey White the other from Joe Fisher.
Get out your DVM.
Old Oct 31, 2022 | 10:14 AM
F-85 4-4-2's Avatar
Thanks, and thanks for the links, too. It stayed at 14V for 5-6 minutes, then dropped to the 13.1V.
Old Oct 31, 2022 | 03:59 PM
Heat somethings breaking down. Bridge diode.
DVS18th
Jun 8, 2022 12:07 AM
ELECMAN
Mar 18, 2020 02:17 PM
antman94
Nov 24, 2013 08:57 PM
1977 Delta 88 Flint
Jul 27, 2013 05:02 PM
TenMidgets
Jan 14, 2013 03:41 PM
