72 Cutlass Supreme Power steering belt/pulley squeal
Old Oct 16, 2018 | 08:24 AM
AJFink's Avatar
Just got my engine and trany in so it can be driven on a trailer to go to the paint shop. All I have is a running shell, but when I rev it up the power steering belt/pulley seams to be squealing. I have two belts running over the power steering pump pulley, one the alternator and the power steering pump belt. both are set as close as I can tell as far as tension. The belts are new NAPA belts the best they have. The pulleys where blasted and repainted. Are things just too new or do I have the tension wrong.
Old Oct 16, 2018 | 08:53 AM
The power steering belt is likely too loose. Completely loosen the alternator belt, then tighten the power steering belt properly, then tighten the alternator belt.
Old Oct 16, 2018 | 09:05 AM
AJFink's Avatar
Beings the power steering belt is so short how tight? I think the book calls for 1/4" to 1/2" slack that seams a lot for such a short distance.
Old Oct 16, 2018 | 09:42 AM
SEARCH is your friend:
https://classicoldsmobile.com/forums...lt-squeal.html
https://classicoldsmobile.com/forums...ng-squeal.html
https://classicoldsmobile.com/forums...lt-squeel.html
https://classicoldsmobile.com/forums...et-issues.html
Also, you might want to look at the emblems on your front fenders for the spelling of CutlAss.
Old Oct 16, 2018 | 09:59 AM
AJFink's Avatar
Thanks Joe
On both of my short comings.........Can't believe I did that........MORE COFFEE!
marzgtp1
Jan 16, 2022 06:19 AM
Toms cutlass
Aug 29, 2018 07:41 PM
kansjfr
Oct 19, 2014 10:38 AM
70Delta
Aug 9, 2014 02:44 PM
mdfedewa
Aug 30, 2012 07:49 AM
