1965 Radiator replacement
1965 radiator is different then the 66-67 radiator that we have.
Is there any other radiator that works out there that would fit this car?
I have a corvette radiator from an V8 S10 swap with the transmission cooler built in. I am going to see if it would work.
Just wondered if anyone else knew of a radiator of a similar size from a different car before shelling out $500 for a brand new radiator
i tried like hell to find the right factory replacement radiator for my 65, but no luck. i ended up finding an aluminum radiator with the inlet & outlet in the correct location, plus the built in trans cooler in the bottom tank. i had to remove the lower radiator support and fabricate an new one, and i also made a new upper bracket to hold it snug.
you'll have a tough time finding an original replacement....
http://radiatorbarn.com/search.php?product=radiator
Genuine copper core, brass tank radiators are available for '65 Cutlass/F85 with 330 c.i.
