1965 Radiator replacement
Old Mar 20, 2012 | 02:24 PM
Andrew7dg's Avatar
1965 radiator is different then the 66-67 radiator that we have.
Is there any other radiator that works out there that would fit this car?
I have a corvette radiator from an V8 S10 swap with the transmission cooler built in. I am going to see if it would work.
Just wondered if anyone else knew of a radiator of a similar size from a different car before shelling out $500 for a brand new radiator
Old Mar 21, 2012 | 07:41 AM
1965cutlassragtop's Avatar
i tried like hell to find the right factory replacement radiator for my 65, but no luck. i ended up finding an aluminum radiator with the inlet & outlet in the correct location, plus the built in trans cooler in the bottom tank. i had to remove the lower radiator support and fabricate an new one, and i also made a new upper bracket to hold it snug.
you'll have a tough time finding an original replacement....
Old Mar 21, 2012 | 07:58 AM
Texascarnut's Avatar
Geezer
http://radiatorbarn.com/search.php?product=radiator
Genuine copper core, brass tank radiators are available for '65 Cutlass/F85 with 330 c.i.
Old Mar 21, 2012 | 08:05 AM
i had plenty of places claim they had the right one....however, after going through 4 that were supposed to be correct but never were, i opted to go with the aluminum to reduce weight and improve cooling performance. they were always either too tall, too wide, wrong inlets/outlets, no tranny cooler, etc.
SteveL442
Aug 19, 2010 02:59 PM
poorboy_616
May 18, 2010 08:45 PM
poorboy_616
May 17, 2010 09:54 PM
super88
Jul 19, 2008 01:46 PM
HAFROD
Mar 20, 2008 04:45 PM
