Would 2 alternator output wires to reduce heat?
Old April 29th, 2014, 12:09 AM
cfair's Avatar
Gang
Just prepping a new to me harness for my 66 98. Already have to HEI and internally regulated alternator on it and they work well.
I've soldered up a 6 gauge wire to the horn relay junction block to handle the higher amperage output for the 10/12 SI.
I have a spare 10 gauge which is the right length. Does it help, hurt or not matter to run a redundantly alternator output line?
I'm thinking it might reduce heat build up from higher amp newer alternators, but then 6 gauge is pretty big and it might not be needed.
What say you? Unneeded complication or reasonable safety precaution?
TIA
Cf
cfair is offline
Old April 29th, 2014, 02:38 AM
Unless that's one hell of an alternator, 6ga is already overkill.
Keep the other wire for a different project.
MDchanic is offline
Old April 29th, 2014, 08:43 AM
2 '66 98's
bigoldscruiser's Avatar
As MDchanic says, the extra carrying capacity is not necessary here but the idea is good in case you need it in another application. Just remember to keep both conductors equal in size, type and length to enable them to carry the load equally.
bigoldscruiser is offline
Old April 29th, 2014, 09:19 AM
Boldsmobile's Avatar
How long is the 6 gauge wire?
Is it stranded?
What gauge was already in the harness and how long was it?
Boldsmobile is offline
travisbeamon
March 5th, 2013 10:47 AM
bobfo1
June 18th, 2012 04:37 PM
724drcutlass
Site Help
June 15th, 2012 07:00 AM
yeahbuddy
March 6th, 2012 04:22 AM
Quickie
Suspension & Handling
March 28th, 2011 06:48 PM
Quick Reply: Would 2 alternator output wires to reduce heat?
