Idiot light for alternator output.
Old Jun 17, 2012 | 05:12 PM
bobfo1's Avatar
I have a 66 442 that was converted to an internal regulator alternator. I have s/w guages to read the real output for temp, pressure and alternator charging, but at the same time I am using the idiot lights. The problem that I am having is that with the engine running, and the voltmeter showing proper charging, the charging idiot light glows...not brightly, but some. Is this a common result when an internal regulator alternator is used in this circuit?
Old Jun 17, 2012 | 08:47 PM
2blu442's Avatar
Sorry I don't know the answer, but back to the top!
Old Jun 17, 2012 | 08:58 PM
BILL DEMMER's Avatar
Just the facts...
need a little more info...
what alternator are you running? 10si, 12si, cs-series? i assume you came from a 10dn alternator. what is your charging voltage? where did you connect the sense line?(thinner red wire)
bill
Old Jun 18, 2012 | 10:00 AM
stellar's Avatar
stellar
Need more info, but if your alt has a diode trio, 10 or 12 or 15 or17SI type, it may have a defective diode in the trio and still charge with the lite showing dim like yours does.
Old Jun 18, 2012 | 10:06 AM
It's a very common problem when the conversion to internal regulator is not done properly.
Old Jun 18, 2012 | 04:37 PM
bobfo1's Avatar
The alternator that I have on the car is (I think) a 10si, 55 amp. The car is down right now for some other work, but the charging showed 12-14 volts. There is no thin red wire going to the alternator...large red, white, and blue only. The wires going to the external regulator are not used....one of those wires is small guage red...the wires that connected to the external regulator are "capped" as part of the change to the internal regulator alternator.
cfair
Apr 29, 2014 09:19 AM
travisbeamon
Mar 5, 2013 10:47 AM
yeahbuddy
Mar 6, 2012 04:22 AM
EastLansing
Dec 6, 2011 07:18 AM
Gaz Hog
May 11, 2008 02:47 PM
