High Output Alternator??
Old Sep 17, 2012 | 06:31 PM
travisbeamon's Avatar
I'm trying to find a high output alternator for my 1972 Cutlass Supreme but I'm having trouble. Does anyone know a decent brand that makes high output alternators for 72 Supremes?
Old Sep 17, 2012 | 07:01 PM
brown7373's Avatar
How do you define a "high output" alternator? How many amps is your original and how many amps do you want?
Old Sep 17, 2012 | 07:13 PM
Nufo's Avatar
give these guys a look...
http://www.powermastermotorsports.com/
Old Sep 17, 2012 | 07:22 PM
BILL DEMMER's Avatar
Just the facts...
i have 105 amp cs130's that are olds mount ready, minor wiring mods needed. search in parts for sale.
bill
Old Sep 17, 2012 | 09:10 PM
GM is a good brand...
Define what output you need. 78 amp 12SI alternators were factory installed on 307s in the 1980s and bolt onto your motor. If you need more, I buy 105 amp CS130 alternators from full size GMs with the 3800 motor (Bonneville, Eighty Eight, etc) at the wrecking yard for $15. These have the correct mounting bosses to bolt to your existing brackets. Just swap the serpentine pulley for a v-belt pulley. Google "CS130 wiring" for the connections.
Old Sep 17, 2012 | 09:22 PM
Aceshigh's Avatar
I go through a guy who rebuilds and resells high output alternators on Ebay.
He's got minimum overhead and charges very cheap prices and will custom
make it to your size, clock position, and belt style needs. I put in a CS130 140amp
chromed alternator from him for just $140, but I'm using a Taurus electric fan
plus an amp'd stereo system.
http://myworld.ebay.com/billh6800&ss...84.m1543.l2533
Old Sep 18, 2012 | 07:51 AM
455man's Avatar
I bought a CS130 for an '89 Pontiac Safari. It has the correct v groove pulley and mounts right up.
Old Sep 19, 2012 | 10:27 AM
Intragration's Avatar
It may be a silly question, but do you NEED a higher output alternator? Just wondering.
Old Sep 19, 2012 | 02:49 PM
stellar's Avatar
stellar
I have a 105 amp alternator for the external regulator style 10 DN if that is what you need. It is a bolt on with no wiring changes needed. I think yours may be the external regulator type.
Old Mar 5, 2013 | 10:42 AM
ddd777's Avatar
Question
Is there any reason to have more than 63 AMPS for a stock 1972 CS - even with A/C?
Old Mar 5, 2013 | 10:47 AM
ddd777's Avatar
never mind.
found this thread that expands on the topic:
https://classicoldsmobile.com/forums...ator-72-a.html
cfair
Apr 29, 2014 09:19 AM
bobfo1
Jun 18, 2012 04:37 PM
yeahbuddy
Mar 6, 2012 04:22 AM
geckonz08
Mar 17, 2010 04:50 PM
drewt
Mar 16, 2010 07:18 PM
