High Output Alternator??
I'm trying to find a high output alternator for my 1972 Cutlass Supreme but I'm having trouble. Does anyone know a decent brand that makes high output alternators for 72 Supremes?
GM is a good brand...
Define what output you need. 78 amp 12SI alternators were factory installed on 307s in the 1980s and bolt onto your motor. If you need more, I buy 105 amp CS130 alternators from full size GMs with the 3800 motor (Bonneville, Eighty Eight, etc) at the wrecking yard for $15. These have the correct mounting bosses to bolt to your existing brackets. Just swap the serpentine pulley for a v-belt pulley. Google "CS130 wiring" for the connections.
I go through a guy who rebuilds and resells high output alternators on Ebay.
He's got minimum overhead and charges very cheap prices and will custom
make it to your size, clock position, and belt style needs. I put in a CS130 140amp
chromed alternator from him for just $140, but I'm using a Taurus electric fan
plus an amp'd stereo system.
http://myworld.ebay.com/billh6800&ss...84.m1543.l2533
never mind.
found this thread that expands on the topic:
https://classicoldsmobile.com/forums...ator-72-a.html
yeahbuddy
Mar 6, 2012 04:22 AM
