SR59 Battery
Old May 23rd, 2018, 09:18 AM
Chris Cutty's Avatar
SR59 Battery
Supposedly these are the original style batteries used in the old cutlass. I know some people prefer to buy the topper to achieve the same look. Do you guys think this is a good buy? Would you recommend? https://www.batterycentralmall.com/Batteries/TurboStart/Script/SR59_HC.html
Chris Cutty is offline
Old May 23rd, 2018, 10:39 AM
They are getting pretty expensive. I used one on my Fury because it was a show car. On my Cutlass, which is more of a driver, I bought a Walmart battery and removed the stickers. If your not concourse showing your car, spend your money on other things.
oldcutlass is offline
Old May 23rd, 2018, 11:28 AM
Gary
VC455's Avatar
Cutlass 455s used a 71-series battery (larger physical size).
VC455 is online now
Old May 23rd, 2018, 02:20 PM
The SR59 is the AGM version of the original R59 battery. Shop around. Remy sells the same AGM version of the R59 for $200. Speedway sells it for $324. Antique Auto Battery sells it for $260. Of course, be sure to add shipping costs. I've found that often the really low priced vendors have very high shipping costs and the total delivered price ends up being about the same.
joe_padavano is offline
Old May 23rd, 2018, 05:25 PM
I checked my 71 cutlass sx which has a 455 in it and the battery tray is 10 inches not 12. Why do you think that is? Should I try to swap out to the bigger size or let it be?
Old May 23rd, 2018, 07:17 PM
If it's like my car, the battery tray has rusted out and been replaced many times over the years.
Fun71 is online now
Old May 24th, 2018, 05:22 AM
x2
Sam's Club or Costco are the best source for batteries and tires. If you aren't showing your Olds then just get a store bought replacement.
Olds64 is online now
Old May 24th, 2018, 08:39 AM
72 Olds CS
RetroRanger's Avatar
I just replaced my battery in my cutlass. I got an AGM battery at advance auto 3 year free replacement, about $180.
RetroRanger is offline
Old May 24th, 2018, 01:46 PM
Just to be clear, I'm ASSUMING the OP wants a correct-appearing R59 battery. If not, then yes, I've had excellent results with WalMart, AutoZone, NAPA, etc.
Old May 24th, 2018, 04:57 PM
66-3X2 442's Avatar
The R-69 is the correct battery for late 66-67 442's. Nobody has made the R-69 as of now. The only difference between the 59 & 69 is,the 69 is 1" taller.
66-3X2 442 is offline
Old April 29th, 2020, 07:37 AM
Burd's Avatar
Burd is offline
Old November 29th, 2020, 07:24 AM
Burd's Avatar
Please delete
Burd is offline
Old September 15th, 2022, 05:48 PM
Motleyfan's Avatar
Burd... do you sill have any of the toppers available. I have a 77 Trans Am.
Thanks,
Nick
Motleyfan is offline
Old September 15th, 2022, 06:12 PM
Thanks,
Nick
I’m sure he does but I doubt he’ll see your post, send him a private message.
Old September 17th, 2022, 06:16 AM
Burd's Avatar
Yes, pm sent, motleyfan, I think we met at a show.
Burd is offline
FStanley
February 28th, 2023 02:48 PM
chip-powell
October 22nd, 2015 04:56 PM
costpenn
May 18th, 2015 08:10 PM
auto_editor
March 26th, 2015 09:20 AM
Pfiffle
March 3rd, 2008 08:01 AM
Quick Reply: SR59 Battery
