Olds' Cutlass Indicator light Out- Assistance Needed
Old Mar 1, 2021 | 10:43 AM
synoptic12's Avatar
Arrow Olds' Cutlass Indicator light Out- Assistance Needed
On a 1986 Olds' Cutlass Supreme, the right indicator arrow is not lit when activating the signal. The left indicator is lit and works fine. The bulbs outside the vehicle are flashing, both sides. Is this a bulb inside the dash panel? Any assistance is appreciated.
Old Mar 1, 2021 | 11:05 AM
Sounds like the indicator bulb is burned out.
Old Mar 1, 2021 | 12:18 PM
synoptic12's Avatar
Arrow
Thanks very much Joe. Back in again, I guess. By the way, after buttoning up the dash the last time in replacing two 194 lamps, now there is a slight sporadic squeal of the speedo cable. Apparently, I upset something when replacing the instrument panel lamps. Got my hand from behind and sort of stretched the dash panel without removing the speedo cable and shift indicator clip on the steering column shift bowl. Is it essential to remove the 'indicator clip' to take out the dash panel or can I just unplug the speedo cable?
Old Mar 1, 2021 | 12:26 PM
synoptic12's Avatar
Arrow
Here is the location of the clip on shift column.
mitchy
Feb 8, 2016 09:34 AM
mkenny
Sep 29, 2015 08:48 PM
The Flash
May 31, 2014 07:19 AM
kona0197
Aug 4, 2012 03:13 PM
ctrain22
Nov 16, 2009 03:29 PM
