fan switch runs on 'high' only.
Old Apr 3, 2009 | 04:38 AM
Flye's Avatar
67 442, with factory air.
air conditioning isn't hooked up.
fan switch on dash runs the heater fan on 'high' only.
get nothing on the other settings on the switch.
bad switch? a 'relay' somewhere? other?
Thanks for any help in troubleshooting.
Dan
Old Apr 3, 2009 | 05:21 AM
Lady72nRob71's Avatar
If the fuse is good (in the fuse block), sounds like the blower resistor is bad. Not exactly sure where it is located on your car, but I believe it is under the hood in the proximity of the blower motor.
If that is okay, then I would suspect a bad switch or wiring connection.
High speed used a relay and separate fuse.
Old Apr 3, 2009 | 05:49 AM
Flye's Avatar
Thanks.
Am I correct in thinking that since it runs on high, but not the others, that the fuse is evidently good for the high?
How to troubleshoot on switch?
Does anyone know where the resistor would be for the fan motor?
Thanks.
Old Apr 3, 2009 | 11:57 AM
I8AF85's Avatar
help
Not sure if a 68 has the same setup but when I took out my a/c I messed up all the wiring to blower. I thought I read somewhere that you need the wiring on the a/c evap unit still hooked up to work those lower settings. Not totally sure what they are for. I tossed all the a/c stuff so right now I have nothing. I have the blower resistor and relay but dont know what wires to hook to where- so Im probably no help but I could throw in a photo of them - Im sure there pretty similar.
Old Apr 4, 2009 | 05:29 AM
Originally Posted by Flye
Thanks.
Thanks.
If this is like the early 70's setup, there is a fuse under the hood for high and one in the fuse block for the other two speeds.
Sounds like the high speed fuse is good. Check the one in the fuse block (if this is the same setup). I would check the resistor before looking at the switch. Once you find the resistor, remove it and look at it. If burned up and the colis open, then you found the problem.
If good, then we will look at the switch.
Octania
Jan 30, 2016 09:18 PM
Octania
Jul 16, 2015 09:53 AM
Aron Nance
Jun 14, 2013 10:07 AM
oldolds51
May 17, 2010 07:11 PM
GoBigRed
Jun 7, 2008 05:55 AM
