Conv. top motor runs but only when jumped
Old Jun 7, 2008 | 05:55 AM
GoBigRed's Avatar
71RedCutlassConvertible
Question Conv. top motor runs but only when jumped
I have a 1971 Cutlass Convertible with a top that will not go up (or down) using the toggle switch on the dash. I only put the top up/down a couple times a year. To accomplish this, I send my son into the trunk with the end of a 30ft piece of insulated #4 wire. He disconnects that harness, makes the connection and up comes the top (with a little help as there is air in the lines -see thread under Hydraulics). I've owned the car for 4 years and think that the prior owner may have melted something in the wiring system when running the motor for a long time due to the air in the lines.
I popped out the fuel gage to access the swich. My hands are just too big. Is there a way to trouble shoot the switch without removal?
Any tool suggestions to remove the 2 screws?
How do you trouble shoot the circuit breaker?
Am I going down the wrong path?
GoBigRed
Brakes/Hydraulic Systems
15
Oct 5, 2015 01:00 PM
66olds98conv
Ninety-Eight
Mar 21, 2013 12:52 PM
White Spyder
May 27, 2012 10:38 AM
JeremyTA
May 4, 2011 10:13 AM
Flye
Apr 4, 2009 05:29 AM
