Driver side turn signals don't work
Old Sep 7, 2012 | 11:37 PM
Holiday 98's Avatar
1961 Holiday 98
1961 Holiday 98 turn signal issues.
First of all I had no tail light and park light on driver side, only brake light. Replaced all bulbs on that side and we now have everything except signal lights.
My thoughts are the switch in the column as it does seem a bit loose. I do have passenger turn signal.
Is there anything I should check before pulling the wheel and getting at the switch?
Old Sep 8, 2012 | 07:45 AM
rocketraider's Avatar
Oldsdruid
The switch on these cars is actually at the lower end of the column. There's a yoke and actuator rod up at the lever itself. It's kind of involved to get all that mess out, requires special tools, and parts are difficult to find, so let's concentrate on the switch, which is possibly out of adjustment.
To adjust it- Locate the switch and put the t/s lever in neutral position. You will see two small holes in the switch body, one on either side of the actuator rod. Loosen the switch mounting screws and with the lever in neutral position, move the switch body on the column until you can put two .090 pin gauges in these holes. Tighten switch mounting screws and the switch should be adjusted correctly.
The shop book calls for a pair of .090 pin gauges, but a couple of 3/32 drill bits will probably work here.
Might not hurt to spray some contact cleaner into the switch either as corrosion is likely after 51 years.
It's always possible the yoke and actuator are worn. If you've never messed with a pre-65 GM column, I wouldn't do that job without a factory shop manual. If you can't find new, the parts will have to come from a 61-62 GM fullsize car with Hydramatic transmission. Pieces from a Powerglide-equipped Chevy might work but can't promise it will.
Old Sep 8, 2012 | 11:21 AM
White_Knuckles's Avatar
Wow, taking above advise is likely the secret.
When you're at the switch assembly inspecting it, before the alignment effort, I would "jumper" the contact function to verify the circuit works. In other words, the exposed connector points may allow you to insert a jumper or test wire that simulates you "made" the left turn switch position. Verify the lights flash and it's not something down line. You could also meter the switch for continuity (resistance) with a volt-ohm meter without power applied. The problem with this test is, you can read continuity but it may trick you the switch is good but with actual use, a worn contact may drop voltage and won't pass enough current to kick the flasher circuit.
Old Sep 9, 2012 | 06:36 AM
Holiday 98's Avatar
1961 Holiday 98
Thanks guys, I'll get on this next week and let you know how I made out.
Old Sep 9, 2012 | 08:26 AM
kartmaster's Avatar
I know this is dumb... but.
Make sure you replaced the bulbs with the correct ones. My wife managed to fit a single filament bulb into her tail light where there should have been a double filament. Caused all sorts of weird lighting issues.
Old Sep 11, 2012 | 10:03 PM
Holiday 98's Avatar
1961 Holiday 98
Does anyone know how to remove the center cap on the steering wheel? I don't what to break anything.
Feb 26, 2015 02:17 PM
smkn600ctd
Dec 29, 2014 05:38 PM
Othertimes
Oct 13, 2013 04:38 PM
Seff
Jun 18, 2012 01:19 PM
cola
Mar 21, 2008 03:44 PM
