driver side rear turn signals and brake lights
Old Mar 20, 2008 | 07:30 AM
cola's Avatar
Hi everyone.
Does anyone have a wiring diagram for the turnsignal switch for a 1968 cutlass s no tilt steering and ignition on the dash? At the steering wheel?
My drivers side brake lights and turn signals are not working. Disconnected moon shaped connector at base of steering column and applied 12volts to yellow lead(left rear tail lights) lights came on. Hooked connector back up and actuated the left turn signal, nothing. Pressed the brakes nothing. Right side working. Parking/running lights (brown wire) working.
cola
Old Mar 21, 2008 | 03:44 PM
ozoneblue's Avatar
Does your car still have the 3 wire flasher? If so replace it.If not pull wheel &clean& tighten switch Use a good electrical cleaner.
costpenn
Jun 24, 2015 10:38 PM
danimal442
May 2, 2014 07:19 PM
GmMike
Jun 9, 2013 06:36 PM
Holiday 98
Sep 11, 2012 10:03 PM
wizzy01
Nov 20, 2007 04:03 AM
