72 Wiper switch removal
Old Sep 18, 2016 | 07:45 PM
csouth's Avatar
I'm trying to remove the wiper switch from my dash. I am wondering if the entire lever comes out or just the flat slide off of the end? I am pulling and it doesn't seem to release.
Old Sep 19, 2016 | 05:47 AM
don71's Avatar
same but different
I believe you need a tiny allen wrench to remove the piece that says "washer". Look under neath it.
Then the switch is retained by a screw or two from behind the dash.
Old Sep 19, 2016 | 07:35 AM
oddball's Avatar
Allen set screw holds on the tab that you grab. It goes in from the side next to the column. Loosen set screw, pull off tab.
Now the switch is removed from the back, three screws.
Old Sep 19, 2016 | 11:22 AM
oldspackrat's Avatar
1/16" allen wrench.
Old Sep 19, 2016 | 12:01 PM
csouth's Avatar
Yeah, the dash is completely out of the car right now I just need to remove the switch.
Old Sep 19, 2016 | 12:02 PM
csouth's Avatar
Originally Posted by oldspackrat
1/16" allen wrench.
Thanks...
Old Sep 20, 2016 | 07:57 PM
csouth's Avatar
Definitely would have searched all over for the right allen wrench. Thanks for all the help guys got it out.
gwunta
Jun 22, 2024 08:59 AM
oldspackrat
Mar 12, 2015 06:34 PM
brandon reynolds
Dec 18, 2013 03:05 PM
centonze
Mar 4, 2012 09:18 PM
brown7373
Jan 19, 2011 05:32 AM
