53 Pertronix Ignitor
I'm installing an Ignitor system in my 53, I have the flamethrower coil also, I have two questions, do I need to reinstall the old ballast resistor with my new coil? and what do I do with the small earth lead inside the distributor?
Pertronix 1, I have fitted it with the resistor in the meantime and even managed to get her running again after a massive backfire...unfortunately it's still running rough. Ive just bought another set of new leads, just about to fit them.
The red wire from the module needs to be connected to full switched battery voltage, the coil can be wired either way, with or without resistance wire. The small ground wire in the dist. needs to be reconnected to where it was originally.
Going to post more videos on the other thread...not good news.
There is no resistor wire on a 53. It has a ballast resistor. You can leave it in place and just move the wire to the input side of the resistor which has a full 12 volts. Pretty simple.
amphicar770
October 31st, 2010 05:38 PM
