53 Pertronix Ignitor
Old Aug 10, 2016 | 06:08 AM
Eightbanger's Avatar
I'm installing an Ignitor system in my 53, I have the flamethrower coil also, I have two questions, do I need to reinstall the old ballast resistor with my new coil? and what do I do with the small earth lead inside the distributor?
Old Aug 10, 2016 | 06:41 AM
Which one are you using? Pertronix I, II, or III?
Old Aug 10, 2016 | 07:25 AM
Tedd Thompson's Avatar
I believe that you can bypass the ballast resistor on any of them and run a full 12 volts.... Tedd
Old Aug 10, 2016 | 07:38 AM
Pertronix 1, I have fitted it with the resistor in the meantime and even managed to get her running again after a massive backfire...unfortunately it's still running rough. Ive just bought another set of new leads, just about to fit them.
Old Aug 10, 2016 | 07:49 AM
The red wire from the module needs to be connected to full switched battery voltage, the coil can be wired either way, with or without resistance wire. The small ground wire in the dist. needs to be reconnected to where it was originally.
Old Aug 10, 2016 | 08:45 AM
Thanks mate.
Going to post more videos on the other thread...not good news.
Old Aug 10, 2016 | 08:49 AM
redoldsman's Avatar
Proud Viet Nam Veteran
There is no resistor wire on a 53. It has a ballast resistor. You can leave it in place and just move the wire to the input side of the resistor which has a full 12 volts. Pretty simple.
68442Convertible
Sep 4, 2016 04:50 AM
amphicar770
Oct 31, 2010 05:38 PM
Big Todd
Oct 16, 2010 11:38 AM
cessna195
May 15, 2010 02:35 PM
cessna195
Feb 23, 2010 07:16 AM
