10 bolt lengths
10 bolt lengths
I am sure this has been discussed many times but I cant seem to find it... What are the outside drum to drum lengths for the 10 bolts? Looking for a 68-72 and cant recall if the 73-77 are longer?
lengths
67-72 55.25 housing flange to housing flange or 61" drum to drum
73-77 56.25 housing flange to housing flange or 62" drum to drum
64-66 54.25 housing flange to housing flange or 60" drum to drum
Jim
J D Race
As stated correctly 73-77 are not interchangeable with 64-72 rears...just way different rears and chassis set-up
Jim
J D Race
cruiser differences
The shock mounts are extended, and the frame bump stops are sideways compared to sedan and coupe or convertible rears as the frame rails are probably slightly wider where they would bump the rear end housings if it hit a big enough chuck hole. ...But that is about all the difference.
Obviously axle bearings are different too because wagons carry more weight.
