Installation of Longer Wheel Studs
I want to install some 1/4" wheel spacers on my 1970 Cutlass but I need longer studs to use them. From what I can find the stock size is 7/16-20 x 1-1/2 long with a 0.472 knurl. I will probably get some ARP or Moroso studs at 2-7/8 length and cut them down to fit. Will a 0.480 knurl work? Can I install them without taking the axles out?
Thanks to another thread that I found here, I found some +1/4 studs in stock locally from Dorman.
Check out post #17 in this thread to see why I always discourage folks considering using wheel spacers or bolt pattern adapters:
https://classicoldsmobile.com/forums...e-wheels-9336/
