3.42 ring and pinion-vendor
Who sells a 3.42 gear set for my 8.5 12bolt rear in my 70 cutlass at a reasonable price? Been searching and I find plenty for a 10 bolt but have not found anything for a 12 bolt rear end! Any replies are greatly appreciated!
Jim, a member here, is a differential builder. He can supply you with all the parts you need. His screen name is Monzaz . Reach him here thru pm or go to his website http://www.jdrace.com/
Jim is a good resource for O-Type parts for sure.
Richmond Gear makes/sells ring and pinion sets for the O-Type rear, but they are made to fit the factory 3.08-3.23 carrier.
https://www.richmondgear.com/wp-cont...n1.pdf#page=32
I used this;
http://www.ronsmachiningservice.net/
They had everything in stock for O-axle, good prices, fast delivery and working online support.
If those are factory gears the aftermarket ring gear won't work correctly as they are made for the 3.08-3.23 carrier. Years back someone had made ring gear spacers to use the aftermarket gears on the 2.56 carrier but you would be going the opposite way. You may need to locate a carrier to go along with the new gears.
Jim aka Monzaz is a great source for Type O parts. You may also wish to contact Brian Trick.
RAMBOW
Drivetrain/Differentials
Aug 25, 2011 09:31 PM
