3.42 ring and pinion-vendor
Old Mar 18, 2020 | 02:19 PM
meoff's Avatar
Who sells a 3.42 gear set for my 8.5 12bolt rear in my 70 cutlass at a reasonable price? Been searching and I find plenty for a 10 bolt but have not found anything for a 12 bolt rear end! Any replies are greatly appreciated!
Old Mar 18, 2020 | 03:09 PM
jmcghee's Avatar
Jim, a member here, is a differential builder. He can supply you with all the parts you need. His screen name is Monzaz . Reach him here thru pm or go to his website http://www.jdrace.com/
Old Mar 18, 2020 | 05:08 PM
Jim is a good resource for O-Type parts for sure.
Richmond Gear makes/sells ring and pinion sets for the O-Type rear, but they are made to fit the factory 3.08-3.23 carrier.
https://www.richmondgear.com/wp-cont...n1.pdf#page=32
Old Mar 18, 2020 | 07:22 PM
I also highly recommend Jim (monzaz) for parts. He will answer any of your questions and supply the parts needed at reasonable prices.
Old Mar 18, 2020 | 09:28 PM
OLDSter Ralph's Avatar
What ratio do you have now ? Monzaz is the guru !
Old Mar 19, 2020 | 02:25 AM
slade69's Avatar
I used this;
http://www.ronsmachiningservice.net/
They had everything in stock for O-axle, good prices, fast delivery and working online support.
Old Mar 19, 2020 | 07:35 AM
meoff's Avatar
Currently has 3.91 and the local racetrack has been shut down for a while now. So want a more streetable gear.
Old Mar 19, 2020 | 10:12 AM
If those are factory gears the aftermarket ring gear won't work correctly as they are made for the 3.08-3.23 carrier. Years back someone had made ring gear spacers to use the aftermarket gears on the 2.56 carrier but you would be going the opposite way. You may need to locate a carrier to go along with the new gears.
Old Mar 19, 2020 | 11:46 AM
meoff's Avatar
Thanks for the replies! And Jim is messaging me with the correct information that I need! Again thank you to everyone!
Old Mar 19, 2020 | 10:17 PM
oldsmobiledave's Avatar
to re-use your original carrier you will need an OEM 3.42 crown and pinion. The aftermarket 3.42 gear set is designed to work on the 3 08 / 3.23 and new modified 8.8" carriers.
Jim aka Monzaz is a great source for Type O parts. You may also wish to contact Brian Trick.
Stevec
Drivetrain/Differentials
Aug 22, 2013 05:07 PM
Mike6970
May 14, 2013 03:05 AM
RAMBOW
Aug 25, 2011 09:31 PM
1969w3155
Apr 15, 2010 05:17 AM
shvelhed88a
Sep 4, 2007 08:47 AM
