center console
You did not say if it is an automatic or stick shift.
Column is 64-66 67 went to a colapsable column and had emergency flashers.
64-69 on a manual shift console (very hard and expense to come by these days)
64-66 on an automatic console. 67-69 you can probably make fit but is not correct. Point to be aware of 64-66 floor shift auto shifters have issues with the shifter shaft. Many will tell you it needs a new T handle. But, the problem is that the mounting tabs on the shifter shaft break off.
Hope this helps
Larry
Hope this helps
Larry
bear71
March 27th, 2007 08:59 PM
